Knock Sensor Help, Please
Old Jul 16, 2005 | 08:16 PM
dfl33094's Avatar
4th Gear
On my 2002 TL non-S, I am getting the OBD code P0325 (Faulty knock sensor on bank 1). Where is the sensor and is it hard to replace?
Thanks in advance,
Daniel
Old Jul 20, 2005 | 11:41 PM
dfl33094's Avatar
4th Gear
Knock sensor?
Is there anyone here who can help?
Old Jul 21, 2005 | 03:22 PM
brakejob's Avatar
:brakejob:
http://www.acuraparts247.com/sunnysi...All&vinsrch=no
the knock sensor is #8, and it's cheap... as to if it's easy? ...
I can't really tell if it is in the side of the engine or if it is in between the cylinders, underneath the manifold and intake runners... we need someone with a helms to post in here
If its on the side it's easy, just gotta get your hands near it... if its in the center, going to need to remove the intake manifold runners, and everything else to get access down there...
easy for me but what's your skill
Old Jul 21, 2005 | 03:49 PM
fsttyms1's Avatar
appears as though its under the lower IM in the above pic
Old Jul 21, 2005 | 07:05 PM
dfl33094's Avatar
4th Gear
Last week I took off the upper intake manifold to clean out the carbon and I replaced the EGR valve. I'll have to do it again and a bit more to replace this knock sensor. Thanks.
Daniel
Old Jul 21, 2005 | 07:40 PM
brakejob's Avatar
:brakejob:
Daniel
good man, those of us who can work on our cars are a dying breed
Old Jul 21, 2005 | 10:41 PM
fsttyms1's Avatar
you can just call me the teacher!
Old Jul 25, 2005 | 12:55 PM
dfl33094's Avatar
4th Gear
more trouble...
I took apart the intake manifold and the wire leading to the knock sensor is gone! I cannot believe that mice live there and chew away at that one cable, but fact is that it's gone. I guess I am off to the Acura dealer....
DL
Old Jul 25, 2005 | 01:38 PM
brakejob's Avatar
:brakejob:
fuck! sorry bro
Old Jul 25, 2005 | 02:23 PM
fsttyms1's Avatar
DL
trace the wire(to where its been chewed to and splice in a new one. (there have been a few members that have had this issue
Old Jul 13, 2006 | 11:26 AM
jalalzia's Avatar
I have the same problem with my knock sensor. Wires are chewed up. Can someone please give me a procedure to replace the sensor. I am quite handy mechanically, and have worked on VW's before, but never an Acura.
Thanks in advance!
Jalal
Old Dec 5, 2006 | 12:34 PM
djdonte's Avatar
i got the same code. Apparently that sensor is on the engine block and the stealership estamates the cost to be about 450
Old Dec 5, 2006 | 08:39 PM
Atrain's Avatar
KS usually don't go bad. You may have a chaffed wire or a short to ground.
A-Train
RobbDizzle
Oct 15, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
STL TL-S
Sep 23, 2015 08:52 PM
