Just hit the 100k milestone
Old Oct 12, 2007 | 11:52 PM
S1CK TypeS's Avatar
B A N N E D
Kinda sad but my car now has over a 100k miles. I did treat it today to new thermoblock spacers. gave the manifold, tb, and intake a nice cleaning. the rpms seem to be goin up a lot faster. Its gotta few more goodies coming very very soon. 300WHP is around the corner
Old Oct 13, 2007 | 12:01 AM
AZN.M3NACE's Avatar
USDM -> JDM
wow... my 03 TL-p is only at 69,111 how far do you commute to work?
Old Oct 13, 2007 | 12:12 AM
death's Avatar
Congrats! I'm about to hit 50k
Old Oct 13, 2007 | 01:11 AM
hairything's Avatar
damn 100k. I guess I'm lucky 'cause I bought my used '03 TL-P w/ 41000k miles just about a month ago.
Old Oct 13, 2007 | 02:18 AM
PiZauL's Avatar
W00t
Hitting 56k here.. got a long way to go.
Old Oct 13, 2007 | 08:58 AM
Never Summer's Avatar
I currently have 99,940 miles on my 2000 TL-P here, I assume sometime this weekend I'll hit the big 100K. It's sad, I want a new car once that comes, or just a new engine and a 6-speed.
Old Oct 13, 2007 | 09:50 AM
wise2k's Avatar
keep rolling man, long way to catch up with some of us! 99tlp here, 194k approaching 2ck in a couple of months weird thing is i called acura and they told me they have no record of any warranty work done on my car, so it seems i might stilll be on ma original tranny too at 194k miles.
Old Oct 13, 2007 | 10:31 AM
JPTL-S's Avatar
アキュラ 力
Congrats and welcome to the club I've got an '03 with 115K and still running strong
Old Oct 13, 2007 | 08:26 PM
S1CK TypeS's Avatar
B A N N E D
i used to commute 80 miles to work round trip and then 40 miles to school round trip. some days i did 120 goin to work and class
Old Oct 13, 2007 | 08:58 PM
01tl4tl's Avatar
get ready to drop some cash- time for water pump and timing belt/tensioner, spark plugs, seafoam, full detail and more
Then its like new car again
replace the car at 100? why- the engine is just getting broken in then~
throw some new struts and a service at her... and keep driving
Old Oct 13, 2007 | 09:42 PM
S1CK TypeS's Avatar
B A N N E D
shes gets detailed atleast once a month, already seafoamed it, spark plugs are on the way. ill wait till the water pump and the belts go, that'll give me enough time to get my funds together. she feels strong as ever, ill be keepin her for a while since i jus finished breakin her in lol
Old Oct 13, 2007 | 10:09 PM
Bob_F's Avatar
100,000 miles used to be a considered an "end of life" marker for a car. But that's no longer the case.
With proper maintenance there's no reason that a TL can't reach 200,000 or even 300,000 miles. There's really nothing that can't be repaired or replaced.
My 1999 TL just passed 200,000 miles and it's still running great.
Old Oct 13, 2007 | 10:13 PM
Lo Pan's Avatar
B A N N E D
how many trannies are you on? 1?
Old Oct 13, 2007 | 10:17 PM
orgnlprankster7's Avatar
08 Civic SI
Old Oct 13, 2007 | 10:22 PM
S1CK TypeS's Avatar
B A N N E D
i bought the car with 48k and i went thru 2 trannies. according to the service records the car had the tranny replaced with the original owner. so 3 trannies
Old Oct 13, 2007 | 11:28 PM
01tl4tl's Avatar
our moderator- fsttyms1- has well over 250k, swapped the motor and trans at 200 for a 6speed, that was after 5, count em, 5 transmission failures
Motor was perfect on teardown inspection- still had the crosshatch marks in the cylinders!
Old Oct 14, 2007 | 01:32 AM
Bob_F's Avatar
My 1999 TL is on its second transmission. The previous owner replaced the original transmission at 173,000 miles. Of course, the 4-speed transmissions used in the 1999 TL are generally more reliable that the 5-speed model used in the 2000-2003 TLs.
Old Oct 14, 2007 | 02:06 PM
ChrisQ1980's Avatar
hates the winter
If you wait for the timing belt to "go" your engine will be toast. So I would really start saving for that right now. The timing belt/water pump service is the most important service to perform.
Old Oct 14, 2007 | 04:37 PM
S1CK TypeS's Avatar
B A N N E D
how much will tht service cost?
Old Oct 14, 2007 | 06:15 PM
eyesnake02's Avatar
5-6 Hundred
Old Oct 14, 2007 | 07:25 PM
S1CK TypeS's Avatar
B A N N E D
Originally Posted by eyesnake02
5-6 Hundred
damn thts a lot. how much of this service is diy possible?
Old Oct 14, 2007 | 09:40 PM
eyesnake02's Avatar
non if ur gonna DIY urself might as well do th e whole thing urself.
Old Oct 16, 2007 | 02:09 AM
SodaLuvr's Avatar
5-6 Hundred
More like $800+
SodaLuvr's Avatar
There's zero room for error, I'll tell you that.
Mess up the timing when you do the timing belt, and your engine is toast.
Old Oct 16, 2007 | 09:33 AM
S1CK TypeS's Avatar
B A N N E D
how many hrs of labor do u think itll take?
Old Oct 16, 2007 | 11:01 AM
01tl4tl's Avatar
About 4-6+ hours at the shop- for someone who knows where all the bolts are and can work blindly and still know what they are doing
the 105 gets valve adjustment in addittion to the water pump-timing belt -tensioner etc etc
Thats removing most everything from the top and side of the engine- just to get at the work area- then hooking it all back up correctly is the real skill
You can change the plugs yourself if you are trying to cut down $
Always look for a private shop and ask how many they have done
They have insuranc if they screw up
Old Oct 17, 2007 | 01:33 AM
cfive's Avatar
88,800 here 02 tls with a busted headlamp! LOL
Old Oct 17, 2007 | 08:06 AM
snowman81's Avatar
Sippy Cup (x2)
I just recently went over 100k miles and had the timing belt and water pump done. The belt was in perfect condition. Looked pratically brand new when the took it off. Almost a waste of money, but at least I know it's new. The timing belt and water pump + labor ran me $700 at a local shop. The dealers wanted a little over $800 for it. A valve adjustment at a dealer will probably run about $300 and maybe around $250 at a local shop. If you do the valve adjustment, it's not hard, but make sure you put everything back the way it was. When I did mine I switched 2 hoses and the car wouldn't start. What a PITA.
Old Oct 17, 2007 | 08:29 AM
stick's Avatar
just went over 60k on my 03 TL S which is also SSM.
i believe i am on the original tranny also.
Old Oct 17, 2007 | 08:33 AM
S1CK TypeS's Avatar
B A N N E D
snow do u kno how much the parts alone ran you
Old Oct 17, 2007 | 09:03 AM
snowman81's Avatar
Sippy Cup (x2)
It was right around $150 for the OEM parts. The rest was labor. Everything else was in good condition so they didn't replace anything else (ie. gaskets)
4drviper
Apr 23, 2025 07:13 PM
08KBP_VA
Oct 22, 2019 01:55 PM
marinrain
ILX
Oct 6, 2015 12:36 AM
jmaxima03
Sep 27, 2015 10:22 AM
