I've looked and can't find.
Old Feb 23, 2014 | 10:13 AM
M224armstrong's Avatar
Is there a diy on installing koni yellow shocks. I just bought them to pair with my eibach pro kit. I am having a very hard time putting it together though. I've looked and can't find anything. Can someone help me out here.
Old Feb 23, 2014 | 10:17 AM
where are you at on your install?
do you have the instructions for the koni yellows?
do you have your car taken apart?
where are you on the install?
Old Feb 23, 2014 | 10:28 AM
I have instructions but it is a picture diagram and makes no sense. I just put the cup down for where the spring sits on and then I got that white cover. I'm at that spot now.
Old Feb 23, 2014 | 10:44 AM
the silver cup can only go one way, if you have it flipped and find out later you'll have to do it all over again.
so, make sure the silver cup sits correctly.
then add the spring, bump stop and dust cover.
then you'll need to assemble the top hat.
depending on which bushings you have, you'll either need to build the top hat with the provided koni hardware.
it's hard, when I installed my konis, i had to dissassemble the shocks a few times to get it all right
Old Feb 23, 2014 | 11:18 AM
Yeah I'm just stuck with this man. Do I have to trim the shock boot to fit on there. Because it's getting stuck at the top
Old Feb 23, 2014 | 01:09 PM
Got it now. Thanks
Old Feb 23, 2014 | 03:04 PM
fsttyms1's Avatar
No trimming is necessary.
Old Feb 23, 2014 | 03:56 PM
Only trimming I had to do was for that white cup. It wouldn't go down over that welded ball looking piece in the top
Old Feb 23, 2014 | 04:01 PM
Now how do I adjust that 20mm height setting?
Old Apr 29, 2014 | 02:13 PM
pjosh's Avatar
Maybe a little late, but I'm sure this could help someone at some point:
http://www.heeltoeauto.com/tech-arti...ra-models.html
Old Apr 30, 2014 | 09:17 AM
fsttyms1's Avatar
With the spring off or compressed.
tonio
Feb 5, 2019 05:43 PM
TLDude876
Dec 28, 2016 03:18 PM
