insulation
insulation
im wanting to insulate my trunk lid, considering i have amps in tehre that get ridiculously hot (the trunk inside is burning hot), any suggestions on what kind? no fiberglass itchy stuff tho. i know Second Skin sells some just for that, but its super pricy
MechEng
this is a crazy idea but...
put a cooling fan where the stock sub was and have it blow hot air from the trunk into the cabin through the rear deck. maybe wire it through the amp so it turns on when the amp does?
just a thought...
just a thought...
try `Reflectex` inside the trunk lid- made for heat reflection- see internet for details- sold in hardware stores,,pretty cheap
dynamat would probably help too--its foil faced right?
I like the idea of a 12volt fan pulling heat from the trunk!
finally that small pass thru opening has a real purpose!
wouldnt putting reflectex on the inner section of truck lid keep heat from pentrating thru so much
I have it on my inner roof of the house and the temp coming thru is down 30 degrees
I will figure out how to remove the cover on my car and try reflectex,
its used on several other projects around the house, and for the car windows when parked
Id bet the majority of the heat in there is coming from the electronics insulating it will most likely only make it worse
You also have to remember that the trunk is vented. When the car is moving air is being pulled thru it and out vent spots so it will draw out the warmer air.
my trunk gets extremely hot from the sun hitting a dark grey car
No amp or anything-no inner heat source
open it at the grocery store and a heat wave blast forth
I take insulated grocery just bags to get the ice cream bars home safe!
who has experience removing the trunk lid cover - just pop out pegs or???
Im not saying it doesnt get hot. The inside of the car gets hotter imo. If his amps are getting hot enough sitting in the trunk off that it feels like it would burn your hand
supraken
04-06-2005 09:19 PM
