type s intake manifold on 2000 tl-p
Old Aug 2, 2010 | 05:03 PM
jayhood787's Avatar
00acura3.2typeS
Exclamation type s intake manifold on 2000 tl-p
Can i install type s intake manifolds on a 2000 tlp ..... Ive read its been done but only on a 99's model.. but they had to change alot of part like fuel rail injectors. do i got to do same because i got a type s motor laying in the garage and just want to put the intake manifold on mine.. And bout the valve actuator can i just run it through the vtec.....
Old Aug 2, 2010 | 08:06 PM
fsttyms1's Avatar
If you have the motor in your garage i wouldnt waste my time putting the intake on, and would put the whole motor in.
Old Aug 2, 2010 | 08:53 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
10 h/p intake
35 h/p engine
Old Aug 2, 2010 | 09:50 PM
YeuEmMaiMai's Avatar
wait what? you'd put the whole motor in? you need to leave town that there common sense lol
lol just kidding, what he said swap motors and get the right ecm
Old Aug 2, 2010 | 11:28 PM
jayhood787's Avatar
00acura3.2typeS
Some1 plz answer ma ????
dont you think i would of done dat i wish the motor was good but the motor smokes "alot" and the valves are sounding.... can someone please answer ma ????
Old Aug 3, 2010 | 01:28 AM
yes u can put it on there it bolts right up just have to get an rpm controlled switch for the IRMC.
valve adjustment should cure the valve noise and since you have the motor out, why not tear it down and see wassup with it?
could be something as simple as valve stem seals
Old Aug 3, 2010 | 10:38 AM
TL3.2000's Avatar
-TL Love-
engine swap>>>> that be what i would look into doing
Old Aug 3, 2010 | 11:30 AM
fsttyms1's Avatar
Ill answer you, not your ma.
It will bolt right up. ONLY the 99 needed the different fuel rails and lower manifolds. You (like said above) will need a RPM switch to activate the IMRC though.
Old Aug 3, 2010 | 11:52 AM
NSXNEXT's Avatar
Do you have the TypeS throttle body too? TypeS airbox?
That will give you the most gains.
Old Aug 3, 2010 | 01:09 PM
CAD Monkey's Avatar
anas!!!
why not just leave the secondaries full time open?? The car will run rough til warm but nothing else should be effected..
Old Aug 3, 2010 | 01:22 PM
dsickles's Avatar
you'll loose low end power if i remember correctly
Old Aug 3, 2010 | 01:36 PM
assclown's Avatar
2000 acura tl FPR
i think i know what he's trying to say....
Translation:
Why must you insult my intelligence? Are you taking me as a fool? You see, my heart longs for this mechanical miracle to serve its purpose, but it is smoking like a chimney on a cold December day and the valves are making an atrocious noise. So if you could please put all the banter aside and answer my query?
Old Aug 3, 2010 | 03:03 PM
jayhood787's Avatar
00acura3.2typeS
cant i just run it through the vtec
Old Aug 3, 2010 | 03:29 PM
fsttyms1's Avatar
i suppose you could but its should open sooner than vtec
Old Aug 3, 2010 | 03:57 PM
phee's Avatar
I got the Shifts
no way to run it through vtec that i know of
Old Aug 3, 2010 | 05:40 PM
fsttyms1's Avatar
Solenoid?
Though thinking about it it would have to turn it on, hold it and turn it off wouldnt it ??
Old Aug 3, 2010 | 05:42 PM
^could run from the solenoid signal but why you want the secondaries open so late is beyond me lol
Old Aug 3, 2010 | 08:06 PM
jayhood787's Avatar
00acura3.2typeS
so that would b a bad idea??? to connect it to the vtec....... how bout just leaving it open
Old Aug 3, 2010 | 09:22 PM
fsttyms1's Avatar
You will loose power down low.
Old Aug 3, 2010 | 10:05 PM
jayhood787's Avatar
00acura3.2typeS
would the car drive nomal???
Old Aug 3, 2010 | 10:07 PM
jayhood787's Avatar
00acura3.2typeS
what bout having a regular switch to open it wit +/-
Old Aug 4, 2010 | 12:34 AM
^ That would be differn't.
make it work.
Old Aug 4, 2010 | 12:53 PM
fsttyms1's Avatar
Why? so you would have to flip it at the right time? Just pick up a RPM switch.
Old Aug 4, 2010 | 09:46 PM
jayhood787's Avatar
00acura3.2typeS
i guess imma try wit a reg switch.. cuz i dnt have da money to buy 1... only if some 1 want to trade it for a type s motor??
Old Aug 6, 2010 | 02:34 PM
fsttyms1's Avatar
Hooking it to a switch would be just about pointless. So your going to flip the switch on every time you hit 4k? Might as well just keep it open all the time.
Old Aug 6, 2010 | 04:53 PM
jjashaa's Avatar
Avant Garde Wheels
lol.. seriously... stop half assing it..
i couldn't finish mine.
Old Aug 9, 2010 | 07:58 PM
jayhood787's Avatar
00acura3.2typeS
i put on the im from the type s with the type s tottle body and the car dosent want to swift up it stay on first gear... i had to put on the old im to make it run rite all that time for nuthin... does nebody knw why
Old Aug 9, 2010 | 09:26 PM
MurkyRiversTL's Avatar
COTM Coordinator
You should really review your posts before hitting submit. Its really hard to understand what it is youre trying to say.
Old Aug 9, 2010 | 09:32 PM
fsttyms1's Avatar
did you have every thing connected properly?
Old Aug 10, 2010 | 10:16 AM
NSXNEXT's Avatar
Any check engine light?
What you installed should have no effect on the tranny shifting.
Disconnect the battery for 20 minutes?
cycdaniel
Dec 17, 2019 10:58 AM
james357
Feb 13, 2016 02:37 PM
kmarqueling
Oct 3, 2015 01:14 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
EvilVirus
Aug 31, 2015 05:24 PM
