Installing exhaust Tip
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
Hi,
I just received the tip this morning. ok as you can see i'm new at doing this kind of stuff myself...I'm looking at the tip and I see three screw holes with bracket that still into the hole. Am I suppose to take those off?
thx
DT
thx
DT
Re: Installing exhaust Tip
Originally posted by Bluedemon73
Hi,
thx
DT
Hi,
thx
DT
Hi,
I see like three u shape bracket in the new tip. Am I suppose to take those off? They stick bout 1/8 into the exhaust and is covering up the screw. Are you following me here? I can send ya pic of you like
thx
thx
Hi,
thx
Hi,
thx
Hey,
thanks again for helping me. Ok. the reason why I ask you that is b/c I'm looking at the screws right now and I see that the screw all screw all the way in and is still not protruding over the u shape bracket. I wish I could attach a pic for you to see. Hang on..maybe I figure this out and put a pic for you to see.
For those of you that have already installed these tips, are you getting any rattling or extra noise from them? I ask because they look like they mount all the way towards the back. Any rattling noise from the inside pipe hitting the tips? And did you guys paint the inside pipes black before installing the tips?
Loving my 08 TLS!
Don't worry, as long as you screw them tight, no rattles at all.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
...and then there was One
Bluedemon73, those U shaped brackets are what will tighten against the (stock) tailpipe. You need to loosen the screws holding the U brackets, and then, because 2 of the U brackets are on top, you need to hold the bracket up as you slide the new exhaust tip over the tailpipe. Get it all nice and even, then tighten the screws on the U bracket just so they are snug, or you may strip them. People on here have said they are soft metal. If you are still having problems, let us know.
I didn't paint my tailpipes black. Looks fine like it is... you really have to get down and look inside to see them. No rattles, either. Just looks nice.
Not a Blowhole
I had no problem installing them - you need to use Blue Threadlocker to make sure the bolts don't back out I found that they had loosened up a lot after a few days - once I "locked" them there have been no problems or noises whatsoever.
Bluedemon73 just do what they said, back out all 3 bolts, till you have enough room to slip it on your exhaust pipe, then tighten all 3 evenly....
Removing the stock tips first offcoarse
I just installed my new 3A tips. They make no rattling noises at all. I did, however, manage to strip one of the bolts but havent done anything about it. I didnt use threadlocker or anything like that, so i might take them back off at a later time. IMO, they look really nice with this car. It makes the TLS look more aggressive. Ill post pics for ya all in a few days( im a lazy guy, so ill post whenever i get around to it). One more thing; make sure u have a good socket wrench set to remove the stock tips, i broke not one, but TWO sockets before i finally was able to remove the stock tips. Chromidium alloy my a$$!!
Hey all,
Thank you for the advises. I must of had a "blonde" momment. this is why I love this board so much....people on here are kewl and helpful...I will post pic of the new exhaust tips![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
David
David
sorry, i cant really tell from the pic, but do you have the tips w/ an angle cut at the end or the ones that look like the stock tips, only much bigger (i have the latter ones)? just wondering
Originally posted by Closer
The hardest part is making the uneven exhaust "appear" straight.
GRRRRRRRRRR
GRRRRRRRRRR
Then I pulled both the mufflers in and up, now mine are perfectly even
Try that
yes i did have a hard time getting the tips straight, especially since i stripped one of the bolts. In the end, i just got them as straight as i could. They look perfect but the black pipe that the tips fit over is resting against the inside wall of the tips so when looking from close up, they appear to be crooked. But after a few days the exhaust caused the inside of the tips to become black, which makes it all but impossible to see the muffler pipe. hey thanx snook, ill try that plastic tie thing to see if it helps, but did your ties melt at all? im just curious
ExcelerateRep
Sponsored Sales & Group Buys
01-06-2016 09:59 AM
ExcelerateRep
12-11-2015 12:58 PM
IIDXholic
10-08-2015 07:53 AM
