Installing exhaust Tip
Old Oct 29, 2001 | 12:50 PM
bluedemon73's Avatar
Cool Installing exhaust Tip
Hi,
I just received the tip this morning. ok as you can see i'm new at doing this kind of stuff myself...I'm looking at the tip and I see three screw holes with bracket that still into the hole. Am I suppose to take those off?
thx
DT
Old Oct 29, 2001 | 12:58 PM
bdimc2001's Avatar
Re: Installing exhaust Tip
Originally posted by Bluedemon73
Hi,
thx
DT
First you have to take off your old tips obviously, and then put in the new ones...Just unscrew the 3 screws so u can get em in the tailpipe and push it to the end. Then just tighten the screws.
Old Oct 29, 2001 | 01:00 PM
Hi,
I see like three u shape bracket in the new tip. Am I suppose to take those off? They stick bout 1/8 into the exhaust and is covering up the screw. Are you following me here? I can send ya pic of you like
thx
Old Oct 29, 2001 | 01:08 PM
bdimc2001's Avatar
Hi,
thx
I know how they look like...I have them too, I'm just not sure why u are confused about it. You can take them then slide in the new tips then put them back on with the screws...U are supposed to use them as support for your tips then put the screw over it and screw it in.
Old Oct 29, 2001 | 01:27 PM
Hey,
thanks again for helping me. Ok. the reason why I ask you that is b/c I'm looking at the screws right now and I see that the screw all screw all the way in and is still not protruding over the u shape bracket. I wish I could attach a pic for you to see. Hang on..maybe I figure this out and put a pic for you to see.
Old Oct 29, 2001 | 06:09 PM
Smelly's Avatar
For those of you that have already installed these tips, are you getting any rattling or extra noise from them? I ask because they look like they mount all the way towards the back. Any rattling noise from the inside pipe hitting the tips? And did you guys paint the inside pipes black before installing the tips?
Old Oct 29, 2001 | 06:22 PM
TypeSDragon's Avatar
Loving my 08 TLS!
Don't worry, as long as you screw them tight, no rattles at all.
Old Oct 29, 2001 | 06:46 PM
SimTypeS's Avatar
...and then there was One
Bluedemon73, those U shaped brackets are what will tighten against the (stock) tailpipe. You need to loosen the screws holding the U brackets, and then, because 2 of the U brackets are on top, you need to hold the bracket up as you slide the new exhaust tip over the tailpipe. Get it all nice and even, then tighten the screws on the U bracket just so they are snug, or you may strip them. People on here have said they are soft metal. If you are still having problems, let us know.
I didn't paint my tailpipes black. Looks fine like it is... you really have to get down and look inside to see them. No rattles, either. Just looks nice.
Old Oct 29, 2001 | 07:21 PM
Road Rage's Avatar
Not a Blowhole
I had no problem installing them - you need to use Blue Threadlocker to make sure the bolts don't back out I found that they had loosened up a lot after a few days - once I "locked" them there have been no problems or noises whatsoever.
Old Oct 29, 2001 | 08:05 PM
snook789's Avatar
Bluedemon73 just do what they said, back out all 3 bolts, till you have enough room to slip it on your exhaust pipe, then tighten all 3 evenly....
Removing the stock tips first offcoarse
Old Oct 29, 2001 | 09:48 PM
CO-TLS's Avatar
I just installed my new 3A tips. They make no rattling noises at all. I did, however, manage to strip one of the bolts but havent done anything about it. I didnt use threadlocker or anything like that, so i might take them back off at a later time. IMO, they look really nice with this car. It makes the TLS look more aggressive. Ill post pics for ya all in a few days( im a lazy guy, so ill post whenever i get around to it). One more thing; make sure u have a good socket wrench set to remove the stock tips, i broke not one, but TWO sockets before i finally was able to remove the stock tips. Chromidium alloy my a$$!!
Old Oct 29, 2001 | 10:05 PM
Loving my 08 TLS!
Here is a pic of mine, can you say comptech exhaust?? hehee!!!
Old Oct 29, 2001 | 10:28 PM
Smelly's Avatar
TypeSDragon,
Your car shines more than the tips. Not fair.
Old Oct 30, 2001 | 01:02 AM
Hey all,
Thank you for the advises. I must of had a "blonde" momment. this is why I love this board so much....people on here are kewl and helpful...I will post pic of the new exhaust tips
David
Old Oct 30, 2001 | 10:55 AM
Closer's Avatar
The hardest part is making the uneven exhaust "appear" straight.
GRRRRRRRRRR
Old Oct 30, 2001 | 06:46 PM
here is a pic of the new exhaust. They looked so much more better than the stock.
Old Oct 30, 2001 | 11:52 PM
CO-TLS's Avatar
sorry, i cant really tell from the pic, but do you have the tips w/ an angle cut at the end or the ones that look like the stock tips, only much bigger (i have the latter ones)? just wondering
Old Oct 31, 2001 | 02:19 AM
CO-TLS,
My tips is the slanted one I got from here. Did you have a hard time making it straight?
David
Old Oct 31, 2001 | 02:53 AM
snook789's Avatar
GRRRRRRRRRR
I used plastic ties. I tied them around the back exhaust hanger, and a part on the car.
Then I pulled both the mufflers in and up, now mine are perfectly even
Try that
Old Oct 31, 2001 | 06:33 PM
CO-TLS's Avatar
yes i did have a hard time getting the tips straight, especially since i stripped one of the bolts. In the end, i just got them as straight as i could. They look perfect but the black pipe that the tips fit over is resting against the inside wall of the tips so when looking from close up, they appear to be crooked. But after a few days the exhaust caused the inside of the tips to become black, which makes it all but impossible to see the muffler pipe. hey thanx snook, ill try that plastic tie thing to see if it helps, but did your ties melt at all? im just curious
ExcelerateRep
Sponsored Sales & Group Buys
Jan 6, 2016 09:59 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
IIDXholic
Oct 8, 2015 07:53 AM
