Installed Comptech sway bars . . . (review)
Old Apr 17, 2001 | 06:16 PM
GIMMICK's Avatar
Thumbs up Installed Comptech sway bars . . . (review)
I finally got a chance to put in the Comptech sway bars into my car this past weekend after having it sit in the living room for close to 2 weeks (I'd like to thank Tim for the speedy delivery). The install itself for the sway bars was very easy, and I estimate it took me about a half-hour for each end. I made it harder on myself by installing a rear Eibach camber kit at the same time (due to some stubborn bolts). After taking the car to the local tire place to get an alignment, I finally got a chance to test out the sway bars. (I should note that I'm riding with a 2" drop on Apex'i coilovers and stock alloys and tires). My car now handles real great, reduced lean when making quick lane changes and carving out high speed turns. With my current setup, the weakest link is now even more apparent -- the stock tires. Even with the tires showing some wear (due to negative camber for the past few months), the sway bars made a big difference in performance. The car is definitely more fun to drive. Next upgrade -- wheels & tires.
Old Apr 17, 2001 | 07:27 PM
bobatimez's Avatar
Post
join the sway club.
Some Said, "TL Type S," Soon They Will Say, "Wannabe TL-S." Laguna METALLIC, Navi, Side Cuts, Tint All Around, Interior Footwell Lighting, Eibach ProKit, PIAA 1700x Fogs custom cut into side holes, Inspire Tails, 17" Type-S Rims with 215/45/17 Bridgestone Potenza RE730's, Visor, Wood Shifter, Comptech Sways making me ride on rails...
http://albums.photopoint.com/j/Album...026&Auth=false
Old Apr 17, 2001 | 07:35 PM
AcuraTL's Avatar
OG
Post
Welcome to the club Now get some nice wheels/tires and you are all set.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads. Mugen front grille. 2 Polk/MOMO 10" subs, Orion Xtreme 500.4 amplifier and Alpine CD changer.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. Matriz ion yellow fog light bulbs(courtesy of Snook). More to come later......
Acura-MDX.com Forum Moderator
Old Apr 17, 2001 | 09:03 PM
SinnedTL's Avatar
Ain't No Other...
Post
Screw you guys!!!
Wanting sways, but dont got no cash flow...
2000 Satin Silver TL, 17x7.5 ATP wheels with Pirelli 215/50/17 P7000SS, H&R OE springs, OEM spoiler, K&N filter, Tint all Around. Inspire Foglight Switch, PIAA 1700X fogs, Polarg M-12 corners.
Next Mods: AEM CAI w/ByPass, Factory Sideskirts, 2002 Taillights
Old Apr 17, 2001 | 10:17 PM
AcuraTL's Avatar
OG
Post
Originally posted by SinnedTL:
Screw you guys!!!
Instead of getting Inspire tails, maybe your next mod should be sway.
Old Apr 18, 2001 | 02:17 AM
Post
I also installed my Comptech sway bars about 3 weeks ago and am still enjoying the flatter cornering. Its such a big difference with less body roll. You're absolutely right about the stock tires not sticking well. Its very obvious now that the rubber needs to be changed.
Just a tip for those considering sway bars: 1) the ride quality does not appear to suffer on bumpy roads (due to the left side suspension affecting the right side on pot holes or right side affecting left on right side pot holes).
2) steering response is better and body roll while turning is flat and secure
3) I concur that the installation is easy. The Helm manual doesn't very explicitly state the procedure to remove sway bars, but there is a photo of the "dog bone" dual hinge between the sway bar and the lower control arm with the hole in the bolt (look at it from the front looking rear). A 14mm box wrench and the hex to hold the screw in position is all you need for the fronts. 12mm box on the rear with hex.
I elaborate on the technique, since when I asked my Acura dealer, then said to pop the dog bones off and replace them (since they typically break). Only the top half needs to be simply unscrewed to remove the front sway bar. Hope this helps someone save some time and money to get flatter cornering than the TL Type S (which sways are improved, but I believe the Comptech sways have less body roll).
2000 TL Navi, Naples Gold
Comptech Sways, 35% metallic tints
Old Apr 18, 2001 | 02:21 AM
Nate's Avatar
Post
I was driving tonight in the rain taking corners like nothing... I love this rubber! Rims, rubber, springs, and sways are a must!
Old Apr 18, 2001 | 08:01 AM
carcaze's Avatar
Post
Quick question ...
When install the sway bar, do you have to take the factory one out first???
Or do u just install it directly without touching anything ??
2000 TL w/ Nav Monterey Blue Pearl, Burlwood Shift Knob, Spoiler and Inspire Tail light
Old Apr 18, 2001 | 08:12 AM
Post
I am loving my sways the cornering now is great the car just goes no roll or lean just straight flat cornering
2001 Naples Gold non/nav, Burlwood shifter, Comptech Springs & Sways, 02 Tails, Clifford I9000, PIAA 1700X waiting install, Inspire Switch waiting install
Old Apr 18, 2001 | 08:13 AM
Post
Originally posted by carcaze:
Quick question ...
I had my install done at the dealer but I am quite sure you have to remove the factory one first
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by deez3.2TLny on April 18, 2001 @ ]</font>
Old Apr 18, 2001 | 10:46 AM
GIMMICK's Avatar
Post
The sway bars upgrade is a direct replacement of the stock sways. So yes you have to remove the stock first.
Old Apr 18, 2001 | 07:39 PM
Shoofin's Avatar
Post
I wanna put mine in alreadyyyyyyyyyy! I had them for like 3 months, waiting for a nice day!
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Old Apr 18, 2001 | 09:26 PM
SimplyEasy's Avatar
Post
Installing mine tomarrow
99' LGM, H&R Sport Springs, 37% Platinum+, AEM SRI, Inspire tailend w/ Gigalux/Polarg bulbs
Our reality is only a faint shadow of the truth
Old Apr 19, 2001 | 10:43 AM
Pimpin_TL's Avatar
Post
sweet, i always felt our handling sucks. i'm gonna try for sways, new shocks, springs, and performance tires and upgraded brake pads.
I feel with these mods our car will be near perfect.
'99 3.2 TL
Black/Black
Burlwood Shift Knob
Bodykit
Spoiler
Tint
Old Apr 19, 2001 | 11:20 PM
liutang's Avatar
Post
How hard is it to do yourself on a scale of 1-10? I don't mind paying the extra $ to have someone do it, but if it's relatively simple, I would like to save that $ towards future mods.
marcelft
Jul 10, 2018 06:17 PM
Onyxthecat
Oct 18, 2016 02:05 PM
drone619
Jan 26, 2016 07:09 PM
MonkeyTrucker
Sep 21, 2015 06:15 PM
k6biv
Sep 10, 2015 06:37 PM
