installation help!
Old Jul 14, 2004 | 03:52 AM
guavawang's Avatar
installation help!
i just purchase a set of extream force fog lights blub for 2nd Gen.
does anyone can teach me how to change it?
also, i am thinking of installing a 2nd gen. AEM air intake.
they said that it gives you about extra 15 HP, and extra 17 extra TQ/per ft.
proved by dyno?
what your Opinion?
please share!!!!
Old Jul 14, 2004 | 04:30 AM
jayhawk815's Avatar
Which AEM air intake? 15 hp & 17 tq seems a little high for either. I don't think either one has been rated this high from dyno results. If someone one would like to confirm this I'd appreciate this.
Old Jul 14, 2004 | 04:43 AM
guavawang's Avatar
correction. but here is a test on honda V6 NON TLS!
here is the link for the intake in DYNO testing.
http://www.aempower.com/pdf/dyno/24-...ccord%20EX.pdf
Old Jul 14, 2004 | 03:46 PM
guavawang's Avatar
please need lots of help!
help!
Old Jul 14, 2004 | 03:50 PM
Bxscig's Avatar
I dont know about the intake doing all that. The fog light bulbs... in the manual the explain how to change it. basically you need 10mm ratchet with at least a 6" extension. there is a hole below, that allows access to the nut. remove the nut and then pop out the fog light housing, change bulb and reinstall.
Old Jul 14, 2004 | 05:35 PM
etxxz's Avatar
@ slide or die @
dud, epect under and close to 10hp IN REALITY out of any CAI depending on the temperature and humidity.
Old Jul 14, 2004 | 06:18 PM
guavawang's Avatar
do you think it's worth it?
the items is about $300.00 is it worth the money to install?
Old Jul 14, 2004 | 10:43 PM
etxxz's Avatar
@ slide or die @
im sure that after the first year of usage (depending on how much you drive) you will save those $300 in gas, and after that, is money in the pocket. You WILL get a +1-+3 in your average AND some good power AND a cool sound.
You can get the item for less than $240 shipped outa this page and you can even install yourself. search around and search the forum.
Old Jul 18, 2004 | 04:45 AM
guavawang's Avatar
thanks!
after the CAI installed, what else will i need to make sure the fuel and air mixer is correct?
do i need to add anything else?
most important, what i can do to the engine that will not void my warrenties and can give me a extra output on the wheels?
thank you for your expertise! and your experiences.
Old Jul 18, 2004 | 10:51 AM
etxxz's Avatar
@ slide or die @
you dont need to add anything...just hook the intake on buddy...is not like the intake pumps the air(turbo), it just lets the engine breath colder(denser) air in a more effective way.
warranties eh...The insurance MUST prove the mod(s) was the cause to void the warranty, otherwise your OK. if not, your pocket will wanna bit you up.
--> mostly exterior mods = i/h/e/p, spark plugs, i wouldnt mess with the engine's insides.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
