indicator lights malfunction
some of my shifter indicator lights and other lights at the center console are not working at times, it is quite intermittent and random what to check? if it goes out completely i could check fuses but this?? I am not sure
make sure all your battery connections and grounding connections are stable. If you need to, use sandpaper to get down to bare metal on the chassis ground connection and clean up the rest of the connectors with the sandpaper as well.
I was having surges of my dash lights randomly until I did all that and it stopped.
01tl4tl (07-06-2011)
I had this problem for the longest time where my d5 didnt light up and nor did my clock, then i hit a bump really hard because i was changing the radio and hadn't realized the road was being paved and all the sudden it worked, so my drive recklessly.
lol that is funny. Yeah there is something is unstable there, my electrical connections someplace. specifically it is drive shiftin indicator lights on the drive shift center console, ventilator lights, AC lights etc everything. I will just have it checked by dealer.
I recently had this same issue, where when i use my left signal, and only my left signal, my whole shifter and gauges would blink as well. Then when I turned on my headlights/parking lights, the left blinker stays on, and it won't blink even when i put to blink. I think something got shorted but I still gotta check it out in a couple days.
Now my tlights are completely off no interrmittency. I am buying helms manual. There is service and electrical. Service seem to have some electrical stuff. Wondering which one is better. Is eletrical be a overkill??
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
HeloDown
09-08-2015 06:51 PM
