IMRC System
Old May 28, 2010 | 09:46 AM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
IMRC System
Intake Manifold Runner Control system...what does it do? I know it is only available on the type-S, and it is controlled by a cable and spring-loaded valve, but how does it work? Is there a butterfly plate inside the intake manifold kind of like inside the throttle body? Is the plate or valve between the IM and the intake runners, or within the runners themselves? How would operation be different between idle and WOT?
BTW, mine is working fine...I'm just curious.
Old May 28, 2010 | 10:55 AM
assclown's Avatar
2000 acura tl FPR
i've wondered the same thing, i know i'm going to have to tweak it when i put my new engine in the car.
Old May 28, 2010 | 11:09 AM
phee's Avatar
I got the Shifts
its a butterfly that opens inside of th eintake manifold. it opens at vtec engagement
Old May 28, 2010 | 11:17 AM
jdjohn84's Avatar
But TL-P have VTEC as well, so why only in the type-S? And I would think it has to be open all the time to some degree or else air couldn't flow through.
Old May 28, 2010 | 12:33 PM
hANDYcaptd's Avatar
It's the Halladay season!
The manifold does allow air flow normally, obviously. The IMRC allows more air, at VTEC engagement.
Old May 28, 2010 | 12:38 PM
phee's Avatar
I got the Shifts
the type-s needs the valve to allow more airflow. the type-s needs more air because it has aggressive cams.
Old May 28, 2010 | 03:23 PM
jdjohn84's Avatar
Cool, thanks guys. Can you see it through the bottom of the IM when you take it off? I've haven't seen much mention of cleaning it during an EGR port cleaning, although there is always mention of the TB butterflies needing to be cleaned. I've actually read suggestions of rinsing the inside of the IM with water after using carb cleaner on the EGR port. Putting water in there with the IMRC valve doesn't seem very smart.
Old May 28, 2010 | 03:30 PM
jjashaa's Avatar
Avant Garde Wheels
you can see it if you take off the top plate
Old May 30, 2010 | 03:55 PM
DC3328's Avatar
Your Garage
it opens at 4100rpm not VTEC
Old May 30, 2010 | 03:58 PM
DC3328's Avatar
Your Garage
you'll see everything when you clean the IM, you take off the top plate and you'll see it right there. it doesnt really get dirty
Old May 30, 2010 | 08:38 PM
assclown's Avatar
2000 acura tl FPR
good to know, i'll be cleaning mine soon once i get the gaskets in from delray.
Old Feb 26, 2021 | 07:17 AM
mossman77's Avatar
Mine seems to open just over 3,000 RPM. It's like flipping a switch. Wondering if something else is wrong.
Old Feb 26, 2021 | 03:03 PM
whitetiger5's Avatar
this thread is over a decade old.
Funmonkey
May 18, 2017 05:06 PM
bioyuki
Dec 31, 2013 08:28 AM
Brick3
Feb 21, 2011 09:05 PM
InspireT
Aug 25, 2008 01:35 PM
Davediego
May 3, 2004 10:35 AM
