Immediate Help Needed Something Ripped!!!!!!!!!!!!!!
Old Feb 23, 2007 | 06:32 PM
vzuptnguyen's Avatar
B A N N E D
Exclamation Immediate Help Needed Something Ripped!!!!!!!!!!!!!!
while attempting to remove rear shocks i accidentally tore out some wire that connects what looks like to a censor on the back of the rotor. Immediate help needed what should i do? what is the part i ripped
Old Feb 23, 2007 | 07:42 PM
dreem1er's Avatar
deal with it
i might be wrong but i think that is the abs sensor
Old Feb 23, 2007 | 07:50 PM
MichiganRich's Avatar
I think it's the sensor that says if you're on 22's or not. Good luck with that, Mr. Goodwrench.
Old Feb 23, 2007 | 08:24 PM
Got_3.2?'s Avatar
get a new 1. i think its something like $100 at da stealership. dont quote me on dat. dat i also believe is the abs sensor. (anti lock break sensor)
Old Feb 23, 2007 | 09:23 PM
01tl4tl's Avatar
Got to be ABS or other wheel speed sensor
Thats why on brake jobs you should hang the caliper from a wire not leave it dangle.
I realize this is different but is shows the unexpected expenses of DIY
Good luck careful with the rest
Old Feb 23, 2007 | 09:24 PM
01tl4tl's Avatar
Great thing about digital cameras is you can walk into the store and say I need one of these parts
Old Feb 23, 2007 | 09:36 PM
Got_3.2?'s Avatar
when u take the abs sensor off u gotta wiggle it off with pliers. sometimes u can tear it apart by pulling on it to hard.
Old Feb 24, 2007 | 03:53 AM
B A N N E D
ok so its the ABS sensor, and all i didnt was pull wire out of plug. anyone think i can just unmount the sensor and try to reconnect the wiring? and if i just leave it for now will it be hazardous?
Old Feb 24, 2007 | 07:57 AM
fsttyms1's Avatar
Thats the abs/wheel sensor. Its like 35 bucks. If you need to drive the car i would tape the wire up or unplug it. just be forewarned that your abs most likely wont work with it disconnected?
Old Feb 25, 2007 | 01:21 AM
B A N N E D
yea mechanic told me if light is on ABS wont work at all, so thats a good thing instead of having one side work. and wire is not like cut from a point outside but its like pull from inside out
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
BKSleeper
Oct 7, 2015 10:20 AM
fallacy
Sep 4, 2015 10:15 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
