Need help ASAP with OE spacers
Old Feb 24, 2007 | 05:09 PM
S1CK TypeS's Avatar
B A N N E D
Well i got the manifold off and test fit the spacer and it doesnt seem cover the small hole on the right at the end. for all those guys with spacers is this normal?
Old Feb 24, 2007 | 05:38 PM
S1CK TypeS's Avatar
B A N N E D
this was just a test fit...im supposed to put the stock gasket then the spacer so hopefully itll fit better. from the pic u can clearly see its not a perfect fit
Old Feb 24, 2007 | 05:45 PM
sbuswell's Avatar
I need 2 more gears
that is not right, it should match up with the egr valve just fine. are you sure you have the spacer on there right and not upside or flip on the wrong side? If you have it on there right it looks like you may have the wrong spacer kit or something.
Old Feb 24, 2007 | 05:57 PM
S1CK TypeS's Avatar
B A N N E D
yup its on the right way well im gonna call oe on monday and see what they can do for me. i have to use their gasket for my tb since i already took that off
Old Feb 24, 2007 | 08:09 PM
S1CK TypeS's Avatar
B A N N E D
well lets see we just encountered another issue. since it is a completely different kit i had to use their gasket for my tb since i had to scrape the OEM one off. Now i have a fuckin air leak and my revs are bouncin up and down when the car is in park.
Old Feb 24, 2007 | 08:55 PM
sbuswell's Avatar
I need 2 more gears
another stupid question did you put the gasket on right? is there a portion of the gasket sticking up from the top of the TB? If so you have it on wrong and that will create idle fluctuations.
Old Feb 24, 2007 | 11:44 PM
S1CK TypeS's Avatar
B A N N E D
yup we tried it every which way possible no perfect fit. so we put it the way it best fit. I had to do that so i can put my car back together
Old Feb 25, 2007 | 12:12 AM
sbuswell's Avatar
I need 2 more gears
that blows, don't drive your car until you get the right spacer kit and gaskets. Having your idle bumping up and down is a very bad thing.
Old Feb 25, 2007 | 12:15 AM
S1CK TypeS's Avatar
B A N N E D
i drove it home from my boys house. we used some metal sealer stuff and it stopped the idle bumping, but i defi need to get my hands on a oem gasket. anyone know where i can get one? nappa?
Old Feb 25, 2007 | 07:34 AM
sbuswell's Avatar
I need 2 more gears
just call your local acura parts counter and buy one there, they aren't expensive and they will have it in stock=you get the gasket now instead of waiting for the parts store to order it.
Old Feb 25, 2007 | 07:37 AM
sbuswell's Avatar
I need 2 more gears
By the way what kind of metal sealer did you use? I hope you didn't ude JB weld or soemthing similar between the TB and IM because that'll be some bitch to get off the TB and IM when you go to take off the TB and install a new gasket, also getting the TB off will be a bitch without tapped the TB with a rubber mallet a dozen times or you may need to tap it with a hammer.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
rockvilleTL
Sep 19, 2015 04:44 PM
yvr_tsx
Sep 15, 2015 01:14 PM
