ideas for increasing mileage
Old Jun 14, 2003 | 03:14 PM
taestee's Avatar
i run about 40% highway, 60% city and i only get about 300 miles to a tank. this doesnt seem very right at all given acura's mileage stats..
i dont even get 300 on most brands of gas. only on citgo do i get that much.
i have 5w-20 in my engine now. im not running A/C either....
any ideas? tips?
Old Jun 14, 2003 | 03:17 PM
Bear2Day's Avatar
Try a tank or two of white Gas (american High test). It`s a little expensive but worth it.
Old Jun 14, 2003 | 03:18 PM
taestee's Avatar
where do i get this so-called white gas?
Old Jun 14, 2003 | 03:20 PM
Dr Groove's Avatar
It sounds like you have a heavy foot. How do you drive?
Old Jun 14, 2003 | 03:21 PM
taestee's Avatar
i dont think i really have a heavy foot. i rarely ever rev up more than i need to shift gears.
Old Jun 14, 2003 | 03:24 PM
hzm82's Avatar
You get 300 miles a tank. Do you fill up just when the gas light comes on? When the gas light comes on there is about 4 gal left in the tank. So you used about 13.2 gal when the light comes on. 300miles / 13.2 gal ~ 23 miles per gal. So thats not that bad when the TL average is 19 city and 29 highway. Ways to increase gas milage have been discussed but I'll list them again. Get a higher air flow intake filter like K&N or Comptech. Always use the highest rating (93 octane) if you can. Make sure the tire pressure is at the recommend psi. Change to denso spark plugs. Don't leave your windows open on the highway. Fuel system cleaner or octane booster. and lot of it has to do with your driving habits. Don't floor it and keep the rpm below 3k, so you don't kick in VTEC.
Old Jun 14, 2003 | 03:28 PM
taestee's Avatar
yeah i usually fill up when the light comes on. around then i have about 270... i figured i'd get 30 on the rest. i had no idea the tank had about 4 gallons left when the light came on. i always thought it was two.
myyyy mistake.
if you put it that way it doesnt sound so bad. :o
Old Jun 14, 2003 | 03:31 PM
hzm82's Avatar
Well our fuel tank cap is 17.2 gal. When the light comes on and I fill up its usually around 13.2 gal I pump in for a full tank. So yeah its around 4 gals left. Try it out on your car and see.
Old Jun 14, 2003 | 03:33 PM
taestee's Avatar
yeah i never really bothered to gauge how much i pump in although every time i fill up, i tell myself im going to note how much i put in.
Old Jun 14, 2003 | 03:36 PM
hzm82's Avatar
Just print a receipt from the gas pump. It tells you how much gal you put in. I been keeping track of mpg for a long time. I usually get 300 miles for 13.2 gal on my work route. So you're not that off if you get 270 per 13.2 gal....just make sure how many gals of gas you used......when the light comes on your car might be slightly off then mine.
Old Jun 14, 2003 | 03:39 PM
hzm82's Avatar
btw on the highway doing about 60-70 miles on cruise control gives our car the optium fuel efficiency.
Old Jun 14, 2003 | 03:44 PM
Eternal TL2k3's Avatar
yeah i tested this actually and if you do 55mph, u dont get as much mileage from your car ... i noted that 70 gave the best mileage for myself. im about 50-50 on city/highway
Old Jun 14, 2003 | 03:49 PM
Dr Groove's Avatar
K & N Air Filter?
hzm82 - does the air filter make any noticeable difference by itself? Considering, that is, all the other variables are done, i.e. keep air pressure at proper p.s.i.
and...Why Denso plugs?
Old Jun 14, 2003 | 03:59 PM
hzm82's Avatar
Re: K & N Air Filter?
I personally gain about 2 miles per gallon from the K&N but its only been on for about two weeks (so its still pretty clean and highflowing). I still recommend getting the K&N filter because anything is better then the paper filter used by Honda and you don't need to replace it (just clean it every 15k). My TL is used for just work so my route is pretty routin so I can guage these things and I check my tire pressure every sunday. We have stock platinum tipped spark plugs so you won't see that huge in milage increase if the plugs are still new (replacing them around 50k is still a good idea). They do last awhile 100k, but I got header installed and going to Denso IK20 (colder tips) gave me better performance.
Old Jun 14, 2003 | 05:06 PM
Tom Blasing's Avatar
is the Mighty Favog
The K&N will work best with other like mods as well. This next part may seem a little strange but bear with me. The filter allows air to flow into the engine more easily creating (for a very brief time) a lean condidtion so the fule injectors put more fuel in the engine. This results in more power (duh). Since you don't need this extra power to more the car the speed you want you don't push on the gas pedal as much. Now the average response I get to this "BS!" but letting up on the gas pedal has a greater fuel saving ratio than running without the filter.
Also, look at it this way. That K&N can run anywhere from $38 to $50 depending on where you get it from. A store will sell a plain paper filter for about $15 and you'll replace it about 10 to 15 times before the useful life of the car is over. But the K&N will last the life of the car and then some.
Testimonial: I used to drive a 94' Talon ES and the sticker on it when it was new said 22 city and 27 highway. With using premium gas (93 or higher and this is also a big plus), a Borla cat-back system and the K&N I would get about 25 city and (get this) up to 40 on the highway at 80 to 85 mph!! I hated to see that car go but it was time for me to get something else since I'm doing better in life financialy.
Old saying: "Let the engine breathe and it will pay you back with power"
Old Jun 14, 2003 | 05:43 PM
SilverUA5's Avatar
get a hybrid if you want to save $ on gas, 300 on a tank from the tl is not bad at all...........you do remember your car is a v6 and weights over 3500 lbs with you in it right?
Old Jun 14, 2003 | 06:06 PM
this is me's Avatar
Old Jun 14, 2003 | 06:10 PM
Yeah, 300 miles to the tank is great for the TL. In fact, I rarely achieve it. Last time I got 184 miles before the light came on. (All short trips, less than 3 miles in heavy stop-n-go traffic, black/black TL with A/C at 68 in 95 degree Texas heat). It was about 14mpg. I only use Chevron Supreme.
Old Jun 14, 2003 | 07:15 PM
Dr Groove's Avatar
I've also heard that a new car has to be broken in before you will see decent gas mileage. This was the case on my Grand Am/GT which I'm selling to get the TL-S. I think I had to wait till it hit 3 or 4k before I got an avg of 23/24 mpg.
What was experience when your TLs were new?
Old Jun 14, 2003 | 11:40 PM
ghost31711's Avatar
take out the spear tire... less weight... you might be able to get an extra mile........ per tank...(okay, i know it sounds stupid)
useing cruize control might help.....
Old Jun 15, 2003 | 12:39 AM
my TL gave me around 23mpg in the beginning and during this spring has bumped up to 25-26mpg. definitely broken in
and cruise for me hasnt yielded an increase in mileage so i just keep it around 70 on the highway and try not to push hard in the city
Old Jun 15, 2003 | 04:33 AM
hzm82's Avatar
plz don't suggest that, I have my spare out because I got 18s and I suggested that the person should try to reduce weight to get more milage and that I had my spare out (and I said I didn't recommend them doing that) and I got so much criticism and bs ranging from "stop trying to think you have a stock car" to "why don't you sh*t before you start driving to reduce more weight" So just to save the arguement from those flamers, don't suggest it.
Old Jun 15, 2003 | 06:36 AM
Dr. TLS
I tend to get best mileage on my car when traveling at ~80mph. Also, I have noticed that turning the AC on does not make any difference at all, which is totally opposite from the way my 4-cyl Accord behaves.
Old Jun 15, 2003 | 09:15 AM
Bxscig's Avatar
I get about 19/20mpg with the damn traffic in NYC.
Old Jun 15, 2003 | 09:48 AM
taestee's Avatar
i feel your pain
Old Jun 15, 2003 | 02:44 PM
fahoumh's Avatar
Shogun Assassin
I get about the same mileage as Bxscig when I'm driving within the city
on my last tank I got about 23mpg...40% highway, 60% city
but driving is pretty spirited and I usually take turns faster than I should be :p
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
marinrain
ILX
Oct 6, 2015 12:36 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
MikeJM310
Sep 24, 2015 07:24 PM
mellsonnj
Sep 24, 2015 04:42 PM
