I broke a lug nut stud, what to do?
Old Oct 17, 2003 | 11:47 PM
stardust's Avatar
Does anyone know what is involved in replacing the lug studs? I tried pounding it out but there is not enough room next to the hub. Anyone with any ideas? Thanks in advance
Old Oct 18, 2003 | 12:17 AM
bulon's Avatar
i thought that thing is strogest part of our car..
how did u break it?
Old Oct 18, 2003 | 12:19 AM
Darkshear's Avatar
l33t
wow... good luck dude, its no small job and you will be kicking yourself
Old Oct 18, 2003 | 10:07 AM
stardust's Avatar
I was replacing the brakes. I had to replace the rear rotors and cut the front ones. I had no problems with the back, when I got to the front the stupid rotors would not come loose so I started hitting them with a hammer. I slipped with a swing and hit a stud messing it up pretty good and could not repair it.
Old Oct 18, 2003 | 10:19 AM
maxx96's Avatar
New Life
Any tire place will replace that stud for a few dollars.
Old Oct 18, 2003 | 10:35 AM
well i never done this car before, so i don't really know. but with other cars, you usually bang it out with a hammer and use a impact gun to pull it back in
Old Oct 18, 2003 | 11:15 AM
songoku's Avatar
BlingBling INSPIRE 32V
You can order that seperately. It's like $4.00
You just need to take the old one out from the hub(hammer it out to the back) & put the new bolt & tighten it.
Old Oct 18, 2003 | 11:31 AM
Tom Blasing's Avatar
is the Mighty Favog
It would depend on if the backing plate (#16) (when unbolted) moves further to the center of the car (pushing it away from you) or moves towards you. Let's hope it's the former. If it does move away from you then it's easy. If it has to move towards you then you'll probably have to remove the hub (#5), remove the backing plate, put the hub back on and pound away at it. Of course a real shop would use an Arbor Press to get it out.
neuronbob
23
Jul 16, 2019 10:48 AM
Jul 16, 2017 07:33 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
