How to remove headlights?
Old Apr 4, 2004 | 04:55 AM
thsiao's Avatar
Happy with my STi!
Can someone please give me a step by step guide as to how to remove the headlights? I know that you have to remove the front bumper so I need instructions as to how to remove the front bumper as well... thanks.
Old Apr 5, 2004 | 04:16 PM
thsiao's Avatar
Happy with my STi!
I forgot to mention that I have underbody neons installed... will they be affected when I remove the bumper or am I just removing the cover of the front bumper? PLEASE SOMEONE HELP ME!
Old Apr 5, 2004 | 05:26 PM
Pure Adrenaline's Avatar
Dragging knees in
You will only be removing the bumper cover piece.
Pop the hood and remove the grille by getting out the self-tapping screws. You will see a long black plastic piece running across the width of the car on top of the headlights. This is connected to the grille, so you will have to get this out, too.
If you look in the front wheel wells, you will notice that there's one bolt on each side, bolted in upside down. It's right where the front bumper meets the quarter panel.
Take those two bolts out, and separate the lower splash guard on the bottom of the car from the bumper. It's held in by self-tapping screws. Easy to remove. After that, it's only held in by clips. Use strong, short pulls to get it out. You will be able to pull it out without much trouble.
Now you should be able to remove the headlights. Honestly, I haven't done it yet, so this is where my knowledge runs out. But it should only be held in by screws/bolts, so just look around in there and you should find them.
Good luck.
Old Apr 5, 2004 | 06:35 PM
thsiao's Avatar
Happy with my STi!
Good luck.
So the entire bumper cover piece is off? Do you think this will affect my neons? Damn... does not sound so easy as people have claimed.
Old Apr 5, 2004 | 06:41 PM
`ill*tl's Avatar
Depends on where your neon is mounted. Is yours "on" your front lip or is it mounted more towards your front wheels?
Old Apr 5, 2004 | 06:44 PM
thsiao's Avatar
Happy with my STi!
I have the OEM body kit, so if you look underneath the car from the front, you will notice that there is a plastic cover covering the bottom of the car so you won't be able to see anything above, my neons are there. They guy who installed it cut a rectangular hole on this plastic cover so the light would go down to the street.
Old Apr 5, 2004 | 06:46 PM
`ill*tl's Avatar
So it's mounted more towards the front, correct? If so..then yeah, I think you may have a problem..
Old Apr 5, 2004 | 06:47 PM
Mr Zipps's Avatar
It wont affect the neons.
http://www.acura-tl.com/forums/showt...threadid=40231
Old Apr 5, 2004 | 06:51 PM
`ill*tl's Avatar
Old Apr 5, 2004 | 06:53 PM
thsiao's Avatar
Happy with my STi!
By the way... what happened to the DIY section?
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rockyboy
Sep 29, 2015 12:05 AM
Desert Ridge
Sep 27, 2015 02:37 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
