how much do i put in??
Old Apr 16, 2007 | 06:18 PM
yankeefan11235's Avatar
im in the process of changing ATF, now approx. 2 1/2 to 3 qrts came out... but i cant tell exactly kuz i didnt measure.... so how much should i put in.. and y do i feel like 2 1/2 to 3 quarts is to little....
thanx in advance
Old Apr 16, 2007 | 07:32 PM
fsttyms1's Avatar
Only 3 will come out. the rest is trapped in the trans. Thats why we say to drain, fill drive x3 to get as much new fluid in the trans as possible. Put in whats necessary. Put in 2.5 qts and check the level, if it needs more simply add more. (3 should have come out)
Old Apr 16, 2007 | 08:04 PM
orgnlprankster7's Avatar
08 Civic SI
i was planning on doing this eventualy, is there a place i should take the old fluid?
Old Apr 16, 2007 | 09:00 PM
dreem1er's Avatar
deal with it
call around.....there has to be a mechanic in your area with a vacuum
Old Apr 16, 2007 | 09:06 PM
01tl4tl's Avatar
Most parts stores and quickie oil change shops are required by law to take used oil at no charge. Limits may apply
The parts place will only take MOTOR oil
the quick change MAY take trans fluid- call and ask- they have to pay to have the stuff taken off their hands so it had to be law to make it happen
Alos check for local county run hazmat recycler place. My town has one near the airport that takes ALL fluids- coolant trans,engine, pool chemicals- unknowns etc, all FREE
Your garbage/refuse pickup company should know too- give them a call
Old Apr 17, 2007 | 06:08 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
so how many quarts for the whole fill-n-flush method? 3 qts x 3 fill-n-flush + 3 qts final fill = 12 qts?
just got tran cooler
Old Apr 17, 2007 | 08:03 PM
fsttyms1's Avatar
Drain fill is whats recommended.
Old Apr 17, 2007 | 10:32 PM
dreem1er's Avatar
deal with it
i didn't know thats whats recommended.....don't dealers use a vacuum for this, and i remember calling about a trans fluid change and they said 120 and it included an acid wash......
Old Apr 17, 2007 | 10:42 PM
08 Civic SI
Acid wash somehow i ont think acid + our trans is a good combo
SidhuSaaB
May 30, 2020 12:40 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
Rcelestino93
Sep 23, 2015 10:01 PM
