how much do i put in??
im in the process of changing ATF, now approx. 2 1/2 to 3 qrts came out... but i cant tell exactly kuz i didnt measure.... so how much should i put in.. and y do i feel like 2 1/2 to 3 quarts is to little....
thanx in advance
thanx in advance
Only 3 will come out. the rest is trapped in the trans. Thats why we say to drain, fill drive x3 to get as much new fluid in the trans as possible. Put in whats necessary. Put in 2.5 qts and check the level, if it needs more simply add more. (3 should have come out)
Most parts stores and quickie oil change shops are required by law to take used oil at no charge. Limits may apply
The parts place will only take MOTOR oil
the quick change MAY take trans fluid- call and ask- they have to pay to have the stuff taken off their hands so it had to be law to make it happen
Alos check for local county run hazmat recycler place. My town has one near the airport that takes ALL fluids- coolant trans,engine, pool chemicals- unknowns etc, all FREE
Your garbage/refuse pickup company should know too- give them a call
Originally Posted by dreem1er
i didn't know thats whats recommended.....don't dealers use a vacuum for this, and i remember calling about a trans fluid change and they said 120 and it included an acid wash......
somehow i ont think acid + our trans is a good combo
SidhuSaaB
May 30, 2020 12:40 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
