How to install ww kit?
Old 08-25-2005 | 06:58 PM
Dreamdtt2000's Avatar
TL 3.2
I couldnt find results with the search so..... I want to install my front and sides ww kit. A shop tried to rip me off by charging me 230 to install it. So I was wondering if it's easy to install? I know I have to take the stock side skirts off but, how many screws is there for the stock ones? Also do I drill my own holes to install it? If someone has a diagram I would appreciate that alot. Thanks.
Old 08-25-2005 | 08:42 PM
FiftyFive's Avatar
Moderator Alumnus
i couldnt get the stock sides to come off but yea your gonna have to drill holes to put the ww up, take your time on the sideskirts or it will come out looking like crap
Old 08-25-2005 | 08:43 PM
MegaKillTron's Avatar
The wood god
they do have quiet a few DIY on this forum and also on acura world they have a DIY
Old 08-25-2005 | 09:05 PM
InspireUA5's Avatar
極品インスパイア32V
the stock side skirts are pretty tight.... you have to unscrew the bottom 4 screws and the front 2 screws first....then push forward and pull it out hard.....
here is mine...
Old 08-26-2005 | 08:07 AM
TL 3.2
O i c sweet. Thanks. Any other tips?
Old 08-26-2005 | 08:42 AM
TL 3.2
What words do I search? I searched ww install and nothing came up.
Old 08-26-2005 | 08:48 AM
InspireUA5's Avatar
極品インスパイア32V
1) turn your wheels to the side that you wanna work with....
2) jack up the car...
3) unscrew the 2 screws in the front side of fender
4) unscrew 4 screws which are at the bottom of the stock skirt
5) push forward so that you can disconnect the clips underneath...
6) pull it out gently...
Hope that it gives you some ideas...
also you may look at DIY section....
Old 08-26-2005 | 09:04 AM
Da_iLLeZt_TL973's Avatar
Future JDM Whore
wow i never even knew you had to drill holes to get the WW side skirts on i thought they go in the OEM spots exactly
Old 08-26-2005 | 09:18 AM
TL 3.2
Thanks man. lol as long as I been here, I don't recall a DIY section. lol i'm retarded. Thanks.
Old 08-26-2005 | 01:09 PM
The wood god
if you go to the website there will be a DIY forum and it will say WW or OEM kit install
Old 08-26-2005 | 01:45 PM
TL 3.2
I'm not trying to be a pain but, where is the diy section on these forums? I don't see it. Also on acura world, the diy section is not working.
Old 08-26-2005 | 02:03 PM
The wood god
i have no clue where it is on this forum i can never find it and as for acura world you go to forums on the top menu then it will take you to their forums list and you click on Do It Your Self it will be near the top
Old 08-29-2005 | 10:43 PM
TL 3.2
Hey everyone. I just installed the ww kit with a friend. Everything went well. It took 2 hours. I have one question. For the side skirts, in the middle, can I drill a hole on the bottom of the car right in the middle part? Right now it is not screwed on because I am scared that that part is where the gas tank is. Is it ok to drill a hole there?
Old 08-29-2005 | 10:46 PM
TL 3.2
Other than that everything is on perfectly.
Old 08-30-2005 | 09:25 AM
TL 3.2
Anyone know if its safe to drill a hole at the bottom of the car? The center bottom of the side skirt? Thanks
Old 08-30-2005 | 12:29 PM
BeemerKiller's Avatar
I have the same questions. Now my sides are only holds by the screws i drilled at the front and back tire wall. I have them on for almost a year, they're not falling but it's really not secure. I'm afraid they'll fall if i hit some shit.
Anyone knows how to secure them please help!!
Old 08-30-2005 | 01:28 PM
TL 3.2
Mine is the same as yours now. If we can get the middle part screwed on it will be secured and it would not shake.
Old 08-30-2005 | 03:28 PM
oVerBoost's Avatar
HELP!
hm, if you're worried about screwing into something, why not try strong double sided tape for now? that should hold it on pretty good. btw, did you guys double side tape the little wings at the end of the side skirts and the front lip? if not, does it kind of flare out?
Old 08-30-2005 | 08:02 PM
TL 3.2
Actually I did on one side but not the other because the other side didn't need it. It didn't flare out. But I tried double side tape in the middle part but it won't hold because the bottom piece does not stick well with the tape.
Old 08-31-2005 | 01:51 AM
exactly, i tried the 3M red tape on the bottom middle part. But gosh, the bottom of our TL is totaly stick-proof.
cycdaniel
12-17-2019 10:58 AM
InFaMouSLink
10-27-2015 06:51 PM
EE4Life
09-11-2015 10:13 PM
HOWELLiNC
09-10-2015 01:39 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: How to install ww kit?
