How do i start moving a stick shift car?
Old Jun 24, 2001 | 01:07 AM
TL-QT's Avatar
Post How do i start moving a stick shift car?
Well i've tried getting a manual car 2 budge a lil. I usually kill it a couple times b4 i can get it going a lil. I notice that if i lift the clutch all the way after i shift the first gear b4 pressing on the gas it stalls. Any advice to help me getting it going smoothly? i can get it going once its moving but at stop signs and red lights its killer. THanx in advance.
Old Jun 24, 2001 | 01:16 AM
StanMan's Avatar
Post
it's all about footwork between the clutch and gas pedals! you gotta gas it when you have let the clutch up so far, or else it stalls. you can always gas earlier, before the clutch hits that sweet spot, but the roaring sound isn't so pleasant. it'll just take some time and practice before you are driving like a pro.
Old Jun 24, 2001 | 01:18 AM
Red Hot TL's Avatar
Post
rev the engine to around 3000 RPM, hold the gas and let the cluth go slowly. after it engages, just let it go all the way.
2000 Red Hot TL w/o nav
Burlwood Trim and Shift Knob
Wood Trim Set
Gutter Guard Grill
Nebraska Legal Darkest Tint
Goodyear Eagle HP Ultra Plus 225/55/16
Photos Of My RED HOT TL
Old Jun 24, 2001 | 01:54 AM
Shoofin's Avatar
Post
Red hot, you don't want to make her look like a real rookie! You very simply pull off the clutch niiiiice and slooooow until you feel and see(on the tach) the revs dip a little bit, at that point, start giving gas simultaneously until you'r off the clutch completely.. A rule of manual driving: You're either on the clutch or off. no in-betweens.. if you want the clutch to last..
Ed
Acura-TL.com - Forum Moderator
'66 Mustang Fastback
'99 Mazda Miata
'99 Acura TL Satin Silver/Ebony, Non/Nav, Comptech Springs and Sways, CL Type S wheels wrapped with 225/45/17 Dunlop SP9000's, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, Gutter Guard Grille, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Old Jun 24, 2001 | 04:50 AM
Lawaia's Avatar
Moderator Alumnus
Cool
Awwww...c'mon guys we all know the correct way to drive a stick.
1. Engage clutch (depress completely to floor).
2. Place shifter to 1st gear position.
3. Press gas pedal down to the floor.
4. Count to 3, lean back, hold on and release the clutch fast!
Now that's how you drive a stick! LOL
Old Jun 24, 2001 | 06:55 AM
Nate's Avatar
Post
IMO you should understand whats happening when you press andn release the cluctch, why it dies whenyou pop the clutch with no gas pedal pressure, etc.
Or just do like Lawaia says!
Old Jun 24, 2001 | 07:18 AM
SL1200MK4's Avatar
Post
Don't try this at home!!!!!!
Well, go to www.howstuffworks.com and read about manual transmission. That will help understand how they operate...
Now, it really depends the type of car that you are dealing with. With the S4 or M3 let's say. All you need to do is easily release the clutch, and the car will go even without any push on the gas. You stall the engine if there ain't enough power to push the car around. So, in a Civic lets' say, you have to give gas at the sweet spot, or in the mean time rev it to 1200-1500rpm and hold it there. Then don't dump but slowly release the clutch. That will help to find the sweetspot. And when you feel the car is moving, you can release the clutch all da way and give gas gentlly at the same time.
Old Jun 24, 2001 | 09:30 AM
FTM-1's Avatar
Post
Well this is what I did some 21 years ago.
When I was 18yrs old & got my first brand new caw with 5 speed manual tranny.
I took the car to hills that did not have much traffic. I would start & stop the car going up the hill. When you can start off going up a hill with out any problems you can start off anywere.I had to retrain myself from automatics. I had learned to drive on them when I was 15. My uncle had told me the hill trick. I had only took one lesson on a stick before I got my car. I learned on my car. The car cut-off about 40 times in front of the dealership on the way home. I was almost crying from this I said I can't drive this car. The hills will help you alot to master the art of the clutch. I did not tear up the tranny at all because I had my 80 Honda Prelude 15yrs with the same clutch. My next 2 Accords also had manual gear boxes. The TL is my 1st automatic car that I have owned. The hills will do it for you. Once you can control the roll back of the car you have got it. Start off on a hill not to steep & start & stop on it. This will help you with the clutch & gas pedal.
2000 3.2TL Nighthawk Black/Ebony/Navigation/ Optional Factory Chrome Multi Spoke 16" Wheels/Factory Underbody Kit/Factory Spoiler/Moonroof Visor/Factory 6-CD Changer/Trunk Mat/Factory Black Wheel Well Trim/Clifford IG8000 Alarm System w/add-ons/51% Tint/Weathertech Floormats /Michelin Arcctic Alpin Winter Tires on Stock Wheels/Factory Car Cover/Factory Gold Emblems Grille & Exhaust Tips
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by FTM-1 on June 24, 2001 @ ]</font>
Old Jun 24, 2001 | 09:32 AM
Shoofin's Avatar
Post
Dude, with any car you can pull off the clutch and start rolling without pushing on the gas.. I do it all the time, especially in my Miata. It's all in the technique..
Ed
Feb 25, 2020 09:57 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:14 PM
tealt
Sep 1, 2015 09:03 AM
