horn dont work
Old May 20, 2005 | 07:03 PM
figueroa1357's Avatar
Lightbulb horn dont work
my horn not working any suggestions what i can do to fix thas might be thanks in advance i have 99 tl with 106 k
Old May 20, 2005 | 07:32 PM
bigguyonbike's Avatar
13.2 @ 104.76mph
check fuse.
Old May 21, 2005 | 01:15 AM
TeknoKing's Avatar
its the fuse underhood, i believe its Light #2 or some crap like that, but if the fuse blew, you wouldnt be able to switch gears.
Old May 22, 2005 | 03:40 PM
Lightbulb
i checked the fuse and the horn that makes the noise there both good
Old May 22, 2005 | 04:30 PM
TeknoKing's Avatar
hmm, interesting. Its hard to imagine that the horn is dead. Check the horn itself, its backing is attached to the metal chasis, which provides the negative ground; make sure that area is clean, and not rusted. If u really want to make sure if it is the horn and not the internal wriing problem, then just connect a hot wire from the battery to the horn, to see if it will work.
Comet2404's Avatar
Flyin' and Drivin'
Lorrrd.... if my horn didn't work I wouldn't be able to drive the car. LOL
On a more serious note... if its not the fuse, then I'm just guessing its the actual horn that needs to be replaced. But I thought we had a total of 3 horns in the car somewhere. Am I correct?
Old May 22, 2005 | 04:32 PM
TeknoKing's Avatar
no, its one lousy little ass horn attached in the back of the front grille area.
Old May 24, 2005 | 12:54 PM
silver2003tl's Avatar
it can also be the switch in the steering wheel, and possibly the wires.
to check switches and wires:
measure dc voltage @ horn from chassy gnd and the horn terminal. If after toggling the horn on/off the voltage doesn't change then it's the wires/button/fuse. otherwise it's the horn itself.
to check switch: take out airbag (be carefull), find the +/- for the horn switch, and check continuity (ohms) while toggling horn on/off. if coontinuity doesn't change then it's the switch, otherise it's the wires or fuse.
Jay
Old May 24, 2005 | 12:58 PM
Smitty's Avatar
the ground connection is my suggestion
Old May 24, 2005 | 06:37 PM
ryanconk's Avatar
Just do what we do in NY without even using your horn,
Old May 24, 2005 | 09:53 PM
whatwasthat's Avatar
Old May 24, 2005 | 10:16 PM
fsttyms1's Avatar
Old May 24, 2005 | 10:17 PM
fsttyms1's Avatar
but seriously, id check to see if ther is voltage at the horn first
mada51589
Jan 9, 2025 04:40 PM
spidermankb
Mar 5, 2019 11:34 AM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
ahsm
Sep 9, 2015 08:35 AM
