Help! Throttle body hoses...
Hey can anyone help me confirm where these 2 connections goes to? It's the 2 connections on the very right of this pic, E-15-12
Please and thanks and greatly appreciated
I agree- there is a system to pump hot coolant/radiator fluid thru the parts of the TB to heat it
In certain conditions- cold, and more strangely= hot and humid- you can ice up the air plate pivot in the TB from the compression and expansion of the moving air = frozen throttle and poor running
Had it happen to me in a small airplane once- carb ice- -what a thrilling few minutes that was to diagnose and fix in flight...on the check ride with the FAA examiner to get my license (groan)!! We run air cooled engines and carbs
and yes I passed the test~
You can bypass those lines when installing an aftermarket intake heat resistant spacer,
but for most users leave it alone
whats up with yours?
Did you have the intake off the car and these hoses are leftovers?
which goes to which side?,
or you confused the vac lines and coolant lines so now it runs bad?
(you wouldn't be the first)
what do you want- a pic?
Pictures would help or even a description of where the connection ties to. for ex. the pointed up connection goes to..... and the connection pointed down goes to etc etc..
did you ck the diy pics on egr clean/ thermoblock install
My car is out with the wife or I would look
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
