HELP...p1768...plus a speeding ticket
yea so i had a wonderful day, drove to Autozone and got a scan...the code was 1768 manufactura control transmission....what the hell does this mean!?!?
as i was comin back...i was pulled over less than 5 minutes from the dorm for doing 59 in a 35....can anyone estimate the pricetag on this?? this is my first ticket, i have court in 2 months
Dragging knees in
Automatic transmission -- your tranny most likely failed.
P1768 is not a standardized OBDII code. It's Acura-specific. That's why it said "manufacturer control transmission" -- you need an Acura scanner to read the specific code. But it is, for certain, pertaining to the transmission. Take it in for service.
As for the ticket, 24 over in 35 is a huge deal in Michigan. 4 pointer, I believe. You said it's your first ticket. Although a big one, you will be ale to get off pretty easy. Invest 500 dollars and get a lawyer.
Good luck.
Good luck.
well, ive been driving with the CEL on for at least 500 miles and the trannys seems fine.....no rough shifting unless im using SS mode
damn 500$?? most people i asked at school said anywhere from 240 to 300
Dragging knees in
Well, I said 500 because that's the going rate in Michigan. California seems to be cheaper.
500 miles with the CEL on? Geez. That's moronic. You could be just causing more damage to the car. I would have it looked at. OBDII doesn't just throw codes because it's bored.
Speeding ticket, anyone in bay area know some lawyers??
i was doing 59 in a 35, and i have a notice to appear in court for "unsafe speeds"
1. how much do you think this will cost, its my first
2. what are my choices, i did a search and read about contesting and traffic school
3. anyone in the bay area have experiance with this or know some good lawyers to call
its retarded the speed limit it even 35 on the road, its a long open stretch near St Marys college where its impossible to stay under 40, dammmmit, i have court in walnut creek
Did I say something wrong??
I was referring to the number of times Liftedoff420 has told the dealer to F off because of what the dealer wanted to charge to diagnose the CEL code and the 'tranny problem'. Now he's gotta take the car to the dealer to get the trans replaced. Kind of ironic.
Dragging knees in
Originally Posted by MikePA
Nope, not at all. Sorry for the confusion.
He should try a different dealership, perhaps?
In caifornia the speeding ticket is priced as follows:
1-14 mph above spped limit will run about 100 bucks
then it increased in $$$ every additional 10 mph
so your ticket should run you around 200 bucks, give or take about 20-30 bucks.
plus about 40 bucks for the traffic school court sign up fee, then the fee for traffic school.
If no traffic school then it is one (1) point on your driving record.
GO TO TRAFFIC SCHOOL, since it is your first.
hope this helps
hope this helps
hope this helps
hope this helps
Check the back of the ticket, it usually tells you how to calculate your infraction (or it will give you a number to call to calculate it). I know the way they do it around here it is 2-3 dollars for every mile over the limit + court costs. This will be a hefty fine indeed.
In california the fine is set by the state juducial council every year. THere should be a web site for the court you can go to. most courts in major Calif cities are online now. But you can only pay the ticket online if you plead guilty. so if you want traffic school, you still ahve to go in.
