Help!!! Engine Over Heating
Old Mar 19, 2005 | 10:29 PM
hnhoj's Avatar
Lately, when I'm stopped at a light or sitting idle, I have noticed that my engine temperature rises quickly from it's normal temp reading (slightly less than half of the gas gauge) to near the red bar. I have almost 95k miles and the coolant was changed at 62k. I'm sure it needs changing but the coolant still has a bright green hue. Anyone else experience this or can help explain the problem? All suggestions welcomed!
Old Mar 19, 2005 | 10:50 PM
speedydoctor's Avatar
Check to see if the fan is running while it is hot. If the fan isn't kicking on, that could speak to several problems.
Let us know...
Old Mar 19, 2005 | 11:18 PM
Daggra105's Avatar
your thermostat might be suck, not opening up to cool the engine.
Old Mar 19, 2005 | 11:19 PM
mrsteve's Avatar
Water pump, thermostat, fans. One of those 3 things.
Old Mar 20, 2005 | 12:33 AM
JaredGMS's Avatar
Meat stick
might try to redo the pump and stat first, then use WaterWetter....it's probably a good idea at your mileage anyway
Old Mar 20, 2005 | 03:53 AM
MikePA's Avatar
Since you mention it overheats only when stopped, it's most likely because the fans are not kicking in. If it were the water pump or thermostat, you'd be overheating all the time.
It's OK when you are moving since then there's enough air flow through the radiator.
Old Mar 20, 2005 | 01:58 PM
NSXNEXT's Avatar
radiator fan switch. I replaced mine at 50K.
Old Mar 20, 2005 | 02:40 PM
Street Spirit's Avatar
Also....you can't really judge when it's time to change the coolant based on colour....it won't really change colour. However, overtime it will break down --- that's when it needs to be replaced. Judged more on mileage and/or time.
Old Mar 20, 2005 | 02:43 PM
Comet2404's Avatar
Flyin' and Drivin'
Yea, after my accident, mine was overheating too. They thought it was the thermostat, which was bad anyways, so they replaced it. It kept overheating, and I finally blew a head gasket. That was a pain in the ass. The cause was a very small leak in the radiator that the body shop, who fucked numerous other things up on my car, didn't fix. Make sure you get it taken car of ASAP.... otherwise you'll blow a gasket and it will cost you a FORTUNE. Luckily insurance paid for mine.
Old Mar 20, 2005 | 02:50 PM
MikePA's Avatar
Originally Posted by Comet2404
The cause was a very small leak in the radiator that the body shop didn't fix.
You didn't notice the antifreeze level in the overflow tank dropping?
Old Mar 20, 2005 | 02:54 PM
Comet2404's Avatar
Flyin' and Drivin'
Angry
I did, and I took it back and they said it was fine. There was antifreeze all over the inside of the engine bay, and the dumbasses said it was just because there was too much fluid in there. I cant believe how stupid this fools are, and how stupid I was for getting my car fixed in Alabama. I should have had it towed to Atlanta.
Old Mar 20, 2005 | 03:04 PM
MikePA's Avatar
Bummer. A can of stop leak would have probably avoided all your problems.
Old Mar 20, 2005 | 09:07 PM
hnhoj's Avatar
After reading some of your responses...I checked the fan and it does kick on. The coolant level is fine. I'll probably take it in to get the thermostat looked at but first I'll try changing the coolant to see if that may resolve anything.. Thanks for all your suggestions and I'll share the results.
Old Mar 20, 2005 | 09:46 PM
hnhoj's Avatar
How much does it cost to replace the radiator fan switch? Anyone have an idea? My fan does kick in, but only when I'm sitting idle for awhile.
Old Mar 21, 2005 | 03:44 AM
MikePA's Avatar
Don't bother changing the coolant unless it should be changed for other reasons. It's not going to solve your problem. Just take the car in and tell them what the problem is. It's easy for them to test since all they have to do is let the car idle and have one guy watch the temp gauge and another watch for the fan to come on.
Old Mar 21, 2005 | 08:40 AM
csilano's Avatar
Just enjoying the ride!
check oil make sure it still looks like oil and not a milk shake. That would indicate head gasket or worse cracked block.
Old Mar 21, 2005 | 08:50 AM
NSXNEXT's Avatar
If the fans are kicking it, it's not the rad fan switch.
Old Mar 21, 2005 | 09:14 AM
Tom Blasing's Avatar
is the Mighty Favog
Have you flushed the radiator? Are you still getting heat inside the car? Are the fans cycling or just staying on all the time?
Old Mar 21, 2005 | 09:25 AM
hnhoj's Avatar
Haven't flushed the radiator and to be honest, I haven't changed the coolant since about 60k. So it's been a tad over 30k, and I'm not sure what the regular interval change time is. As far as the fan goes, I mostly just notice it coming on after I've turned the car off and the fan goes on to cool the engine. During stop lights, I can't hear nor feel the fans kick on, and the temp will climb from less than midrange to almost the red. I just changed the oil a couple of weeks ago at the jiffy lube and they made no mention of discoloration or look in the old oil. You guys are right, I just need to take the car in to get it looked at.
Old Mar 21, 2005 | 10:05 AM
Pure Adrenaline's Avatar
Dragging knees in
Air pockets, maybe? If there are air pockets in the coolant system, then the engine temperature would go up and down.
rockyboy
Aug 4, 2024 10:35 AM
01CLOwner
Oct 9, 2015 01:07 PM
Rachel Lu
Sep 27, 2015 09:53 AM
Sep 17, 2015 09:01 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
