Help with engine light flashing!!!
Old Nov 8, 2006 | 05:28 PM
PhAmBaMs_TL's Avatar
2002 SSM TL-P
I have been trying to figure this out but just can't...
Well this is whats going on when Im drivin if I use the trip-tronic and hold it in second before VTEC kicks in and once I punch it the check engine light will blink for a little bit then disappear. Has anyone else's done this?? I need to find out if something is wrong with my car anyone help... Thanks!!
Old Nov 8, 2006 | 06:01 PM
Blazin_TL's Avatar
Registered User
you might want to go to your local autozone and get the codes read.. then for sure we can find out whats wrong with your car.
Old Nov 8, 2006 | 06:03 PM
fsttyms1's Avatar
Does teh light stay on or just flash?
Old Nov 8, 2006 | 06:18 PM
2002 SSM TL-P
thats the tricky part there is no code and it just flashes and then goes away
Old Nov 8, 2006 | 06:48 PM
fsttyms1's Avatar
Ive seen that a few times with my old motor and with the new when i got tire spin as well. It will flash a few times, but it wont store any codes.
Old Nov 8, 2006 | 07:04 PM
2002 SSM TL-P
is it something normal or is something wrong with the ride? Im drivin like a damn granny because im afraid somethin is gonna f'up if I put too much acceleration....
Old Nov 8, 2006 | 07:20 PM
Kilogram's Avatar
6th Gear
I have the same issue. When I'm in second gear and have the RPMs above 5K for more than 2 - 3 seconds, my check engine light flashes for 5 - 10 seconds. The computer spits out misfire codes. My dealer says I'm not supposed to drive the car like that... The owners manual basically says that as long as I don't red line, I'm fine. Service advisors response 'I know, but you need to baby your TL' I do, but sometimes I feel the need for speed!
Old Nov 8, 2006 | 07:53 PM
fsttyms1's Avatar
Ive never did any thing to mine in 200k miles when it occasionally did that.
Old Nov 8, 2006 | 09:42 PM
Blazin_TL's Avatar
Registered User
i had somthing like this happen to me and it turned out that i needed new coil packs.
Old Nov 9, 2006 | 06:28 AM
2002 SSM TL-P
After you replaced the coil packs was there any difference? Or did it run the same just with no engine light....
Old Nov 9, 2006 | 06:33 AM
fsttyms1's Avatar
DOes yours run differently now?
Old Nov 9, 2006 | 01:12 PM
2002 SSM TL-P
Is seems a little slower but I did do the whole seafoam process (oil, gas, and vacuum line) but I haven't changed my spark plugs yet and haven't changed my oil but im not sure if that would affect anything with the engine light blinkin. It does it rarely but I do notice that I lost torque or so it seems.
Old Nov 9, 2006 | 02:40 PM
fsttyms1's Avatar
Change your plugs and change your oil and see if it happens again. There is no need to drive like a granny.
Old Nov 10, 2006 | 02:55 PM
2002 SSM TL-P
Well changed my oil with Mobile 1 Full synthetic and replaced plugs to NGK Iridiums and damn that cost me alot for that stuff but so far no engine light and car seems like all the power is back my old plugs were pretty bad but well soon see if the stupid engine light comes back
Old Nov 10, 2006 | 03:21 PM
fsttyms1's Avatar
Hopefully it was just a bad plug
Old Nov 12, 2006 | 09:09 PM
twighunter00's Avatar
IDK what u got...never has happened to me when in tiptronic or ever?...
When u find out..post it..
Old Dec 8, 2010 | 12:29 AM
finalcross's Avatar
I know this is a old thread but I was wondering if anyone has solved this.
This has happened twice to me. Once in August after my seafoam, oil change, and NGK Iridium spark plugs change. I went on a spirited ride and once I got on the highway, I was on tiptronic and went from third to second and stepped on the gas like half way. Once I hit vtec, the CEL started flashing so i shifted up to a regular rpm range and it flashed and went away. After that, I never got a CEL light ever. Even when I tested my transmission and stepped on it completely while going 25mph, the tranny just downshifted smoothly and went with no problems.
And it happened again today, I just got on the highway and I shifted from third to second. I stepped on it lightly and once it hit vtec, the CEL started flashing so I upshifted again and it went away.
I guess it has something to do with being in tiptronic and hitting vtec in 2nd gear. My oil level is near the upper mark.
Old Dec 8, 2010 | 08:06 AM
phee's Avatar
I got the Shifts
make sure your plugs are properly gapped
Old Dec 8, 2010 | 08:50 PM
finalcross's Avatar
They should be because I bought them pre-gapped from Advance Auto Parts. Of course it could be pre-gapped wrong but I think this problem only occurs when in tip-tronic and in 2nd gear.
I was on D5 today and when I stepped on the gas, it downshifted to 2nd gear and redlined fine with no CEL or anything and it shifted smoothly.
Old Dec 8, 2010 | 10:13 PM
dudeinaTL's Avatar
Misfire. Bad plug(s) and/or coil(s). You'll have P1399 stored as a pending code if you read the DTC after it happens (but before turning the car off).
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
