heat shield questions
Old Aug 3, 2005 | 03:04 PM
sbuswell's Avatar
I need 2 more gears
Is the exhaust heat shield that big ass piece of metal connected to the undercarriage near the middle of the car? I think it might be the cause of some of my rattling and want to remove it. Is this a bad idea?
Old Aug 3, 2005 | 04:10 PM
tweedle99's Avatar
Isn't that the heatshield for the Cat converter? You can always buy a really big SS hose clamp and just tighten it down.
Did that on my '92 Vigor
Old Aug 3, 2005 | 04:18 PM
sbuswell's Avatar
I need 2 more gears
could the cat heat shield cause a rattling sounds at certain rpm's when the exhaust expands? Where are the other exhaust heatshields? and is it okay to take off the heatshields or not?
Old Aug 3, 2005 | 04:25 PM
Pure Adrenaline's Avatar
Dragging knees in
Umm, shake it around with your hand and see if it rattles...
Heat shields do come loose sometimes and can cause a rattle. So yeah, check it out and see if that's the problem.
Old Aug 3, 2005 | 04:29 PM
sbuswell's Avatar
I need 2 more gears
where are other heat shields that I can check for rattles?
Old Aug 3, 2005 | 06:39 PM
MikePA's Avatar
Did you notice any other ones when you were under the car and found the one in the middle of the car?
Based on the Service Manual, there's one around the cat.
Can you remove it? Acura/Honda installs them for a reason.
Old Aug 3, 2005 | 06:48 PM
fsttyms1's Avatar
you dont want to remove them, just find a way to refasten if possible
Old Aug 3, 2005 | 08:30 PM
sbuswell's Avatar
I need 2 more gears
thanks fsttymes that was the response I wanted not smart ass comments that don't help. I will refasten it if i notice any loose or missing bolts.
Old Aug 3, 2005 | 09:02 PM
MikePA's Avatar
I guess telling you that there's one around the cat and they're there for a reason was too complicated to understand.
Old Aug 3, 2005 | 09:25 PM
MikePA's Avatar
Yep, kris does a great job helping everyone, particularly noobs.
Old Aug 3, 2005 | 09:52 PM
sbuswell's Avatar
I need 2 more gears
hahahaha, noob, i have been on this site longer than you= you are the noob. I don't know everything about my car and figured the heat shield over the cat was the only one, it just sounded like there were others that i havne't noticed. I never gave a second thought to checking out heatshields.
Old Aug 4, 2005 | 03:28 AM
MikePA's Avatar
There are two heat shields. One around the cat and one above the resonators.
Old Aug 4, 2005 | 09:33 AM
fsttyms1's Avatar
Quit fighting 's there are 2 types of heat shields on the car, the 1's on the exhaust parts, and the 1's on the car. the ones on the car are more important than the one on the exhaust. if at all possible try to find ways to refasten them wether its clamps screws or straps
Old Aug 4, 2005 | 10:41 AM
Dragging knees in
If I recall right, there are 3 heat shields. Front bank exhaust manifold heat shield, rear bank shield, and the catalytic converter shield.
All your n00bs are belong to us!!
Old Aug 4, 2005 | 11:39 AM
fsttyms1's Avatar
like i said 2 types. the ones on the exhaust parts and the ones on the car!
cycdaniel
Dec 17, 2019 10:58 AM
06TLMatt
Oct 2, 2015 08:14 PM
navtool.com
Sep 25, 2015 05:15 PM
datadr
Sep 12, 2015 09:12 PM
