Headlight or ignitor
Old Nov 29, 2010 | 12:15 PM
rmcaninch's Avatar
9th Gear
I have an 2002 TL. The passenger side headlight went out. However, when I shut the lights off and turned them on again the headlights worked fine.
Is my HID bulb going out, or is it another issue, like the balast or ignitor?
Thanks for your input.
Old Nov 29, 2010 | 01:51 PM
FirePR2002's Avatar
bringin lead
do a search - many current threads on this same topic
Old Nov 29, 2010 | 03:26 PM
thewrangler99's Avatar
i also have same problem on my driver side. there's no known fix on other threads.
Old Nov 29, 2010 | 03:30 PM
tweedle99's Avatar
try swapping the bulbs to see if the problem still persist. Then you can start narrowing down between bulb, ignitor or ballast.
Old Nov 29, 2010 | 04:05 PM
ChucksCL-S's Avatar
I just had this same problem. Fix was to buy ballasts online (cheaper) and then just wire them into your system, bypassing the OEM ones. I spent $200 and got 2 ballasts and two bulbs,brand was OMNI I think, made in Japan. Perfect stock look too.
Old Nov 29, 2010 | 09:21 PM
maybe bad bulb?? found some threads on other forums
http://priuschat.com/forums/gen-ii-p...-06-prius.html
http://forums.nasioc.com/forums/show....php?t=1597871
Old Nov 29, 2010 | 09:44 PM
one more thread! change the bulbs and let me know if it solved your problem. lol
http://www.acura-legend.com/vbulleti...kering-140161/
Old Nov 30, 2010 | 12:23 PM
rmcaninch's Avatar
9th Gear
Thanks for all the information.
I went online and saw the multiple opportunities to buy the necessary parts much cheaper than a dealer.
I will get the necessary parts and work on the fix.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
