header install?
Old Feb 19, 2008 | 02:18 PM
WDPTLS's Avatar
header install?
first off, let me start by saying i am sorry if this is posted in the wrong section, i dont usually open new threads, so this is kind of new to me . so my issue is i searched and searched for a DIY install for the XS headers on a 2g TL-S. I have the neccessary hardware, the bolts i mean. so my main questions are, where can i get new gaskets and which exact ones should i ask for, and if anybody could post a DIY for this install. Im not a newb, so dont think that. Ive done enough motor work, but just need something to go off of. and also, the bolts that shud be used are the grade 8 heat treated 10MM x 40MM right? thanks an advance for all your future help! you guys rock..
Old Feb 19, 2008 | 03:00 PM
jjashaa's Avatar
Avant Garde Wheels
if you received the XS-power headers, the gaskets should come with it. for any other brand, i'm not to sure. u can get new gaskets from the dealer. don't kno which exact ones but somebody will show up with a diagram and show you which one.
for quick DIY of unbolting:
you could either start by raising the car or not.
- loosen the bolts that hold the stock heads to engine. (of course take off heat sheild too)
- if u haven't lifted it, lift now and get under your beauty.
- if u haven't touched them bolts. spray some pb-blaster / freeze-off for a good 3 minutes or so. i used freeze off. sprayed on for about 2 minutes and waited a minutes and tapped the bolts(all) with a wrench.
- and then loosen bolts connecting headers and catalytic convert.
- loosen bolts that connect head and downpipe.
- then with a help of a friend holding the downpipe, screw off the bolts connecting downpipe to anything.
- downpipe would fall down if a friend isn't there. i used some pillows or bricks to keep the downpipe from falling
- with downpipe gone, i got back to the top and took off the rest of the bolts on heads and pulled them out..
putting everything back on is just going backwards.
if u got XS-P, they provide all the bolts and stuff.. comptech should provide new ones too.
here's diy i went off of
http://www.cardomain.com/ride/184466/19
have fun!
there should be threads about wat bolt you'll need.
Old Feb 19, 2008 | 03:09 PM
ryebreadisme's Avatar
Low and Slow
Buy OEM gaskets from the dealer. The O-rings are ok to use, but the gaskets are terrible. So, go to your nearest dealer for the gaskets.
Old Feb 19, 2008 | 05:32 PM
6MTUA5's Avatar
No He Can't
Get some PB Blaster on those bolts to make your life easier
Old Feb 20, 2008 | 09:48 AM
fsttyms1's Avatar
The manifold gaskets dont need to be replaced. Re-use the stock manifold gaskets.
Old Feb 26, 2008 | 01:21 AM
WDPTLS's Avatar
so i installed the headers, first off let me thank you guys for the help, but damn, getting the back headers off was the biggest pain in the ass ever. i was literally sittin on top of the engine block to get them off, im short, fuck off, lol. but yea, it sounds amazing, definitly more power then before. ill try to get some sound clips up, but thanks guys, definiutly worth the 60 bucks lol
Old Feb 26, 2008 | 01:34 AM
jjashaa's Avatar
Avant Garde Wheels
lol, sitting on your engine block, its alright man.. i jacked up my car and forgot about the rear manifold and ended up using a stool to reach the rear.. i said eff this and i jus laid belly flat on my engine block.. hahaha but yea! good thing you got them on!! have fun with it!
Old Feb 26, 2008 | 07:28 AM
fsttyms1's Avatar
Thats why every one that does DIY stuff should have an old blanket and use that. It works great to lay on on the ground while under teh car, it works great to lay on the motor so you can lay on top for stuff like that.
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
CLsuperhero
Sep 23, 2015 12:53 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
TxRzrBk
Sep 17, 2015 01:07 PM
