Grinding in Reverse only
Old Mar 6, 2011 | 01:21 PM
TL3.2's Avatar
4th Gear
Question Grinding in Reverse only
Hi guys!
I searched but couldn't really find the answer I was looking for. Today I was backing out of a parking space and my transmission just started grinding. It only did this in reverse and drove fine all the way to work and back home. When I got home I tried it again, and still it only does this in reverse. I can probably live without reverse for a little while if necessary, but I'd like to get it fixed.
Any ideas?
BTW, '99 TL-P with 205k or so miles on original transmission as far as I know.
Thank you!
Old Mar 6, 2011 | 01:49 PM
Karanx7's Avatar
Unregistered Member
It's probably gonna need a rebuild. It can get worse as you keep driving.
Old Mar 6, 2011 | 02:03 PM
TL3.2's Avatar
4th Gear
I was afraid that was what I would hear. lol No chance of a sticking solenoid or something simple?
Old Mar 6, 2011 | 02:19 PM
Karanx7's Avatar
Unregistered Member
Grinding noise is usually pretty bad. I don't think it will be anything less than a $2000 fix.
How's your transmission fluid?
Old Mar 6, 2011 | 02:23 PM
TL3.2's Avatar
4th Gear
Fluid's good. I keep it changed regularly, and just changed it in Feb.
Old Mar 6, 2011 | 03:11 PM
TL3.2's Avatar
4th Gear
bump
Old Mar 6, 2011 | 06:30 PM
01tl4tl's Avatar
what fluid have you been using?
ck the magnetic drain plug for evidence of new metal
or send a 3 ounce sample to a lab like blackstone for analysis.
if there is anything bad happening the oil will show it
get the car put on a lift- it can be something besides trans
01tl4tl's Avatar
the tell for warranty replacement trans is blue paint on the trans bolt heads- very easy to see
Jul 16, 2017 07:33 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
STC
Sep 23, 2015 04:36 PM
