Going To The Track-intercooled Tls
Old Oct 1, 2004 | 04:19 PM
SCTL-SS's Avatar
13.68 @ 102.56
I do plan to go tomorrow to the track. I hope to have new and very improved track times and #s. Along with that I will be reporting on tranny results(this tranny has not had any track time as off yet). I don't have the new harness and as a result I'll be using 100 octane unleaded race fuel. I'll try and do a base run and then subsequent runs I will be running with ice in the reservoir to see how much it improves the times. That's all for now, I'm somewhat nervous but I'm hoping for no major issues. If there is any one that can make it out tomorrow and take pictures or video they are more than welcome. The track opens at 10PM until 2AM. It will be at "SPEEDWORLD" in Orlando their # is 407-568-5522. Hope to see you all there.
Old Oct 1, 2004 | 04:25 PM
fla-tls's Avatar
On the way!
Can't wait to hear the results! Do you have any pics of the new setup?
Old Oct 1, 2004 | 05:51 PM
SCTL-SS's Avatar
13.68 @ 102.56
I don't have any but there are plenty off them on the Acura CL sight.
Old Oct 1, 2004 | 09:42 PM
Hurleysurf24's Avatar
your supercharged ot turbo charged .. ive been lookin for tl's in the orlando area ... how far are you from ucf ?
Old Oct 1, 2004 | 11:23 PM
benzo555's Avatar
boo
let us know ur results!
Old Oct 2, 2004 | 11:04 PM
i want to run you once i get my nx kit hooked up
Old Oct 3, 2004 | 03:45 AM
SCTL-SS's Avatar
13.68 @ 102.56
^^^NOT ANY TIME SOON^^^^
results are very disappointing to say the least. Here are the shameful times:
1st Run - Got a 15.96 @ 81.01 HOW AWFUL. The check engine light flashed and VSA light came on and it looked like Christmas on my dash. When I came back through the staging lanes I noticed I only had half of my Supercharger belt, I must off lost most of it on the track. DOUBLE WOE!!!
Thank God the guys from Speed Distributors(formerly Velocity Resources) where there and they had my new GY Gatorback belt(which I ordered in anticipation of the original not making it). BTW: Dean with his black CL-S was there but didn't run, can't say that I blame him as there must off been 250+ cars and motorcycles.
After the belt was installed I got back in the lanes again hoping that would do it.
2nd Run - Went from running in D5 to gate shifting to see if that would also improve things: 15.80 @ 89.27 HOW AWFUL AGAIN. Check engine, VSA, etc...Flashing once more. I did no more attempts as this was hopeless. The car must off been pulling timing to save its life as the car didn't seem to pull past 4000-4500 RPMs. I know that I wasn't getting enough fuel since I don't have a working harness for the E-manage so I was using the race fuel but that didn't seem to make enough difference and that stuff is expensive!!!
So all this in light that the car is running 3-4 more pounds of boost, intercooled, race fuel, brand new wider rubber up front and I went from 13.68@ 102.5 on 93 octane to this. I'm hoping that this is nothing more then an e-manage issue.
If I get the harness in time I'll be back to the track on Wednesday night.
Sorry guys for the poor report.
Old Oct 3, 2004 | 03:47 AM
SCTL-SS's Avatar
13.68 @ 102.56
I'm about an hour from UCF. Best time to catch me is when I'm at the track as it is only 10-15 from the campus.
Old Oct 3, 2004 | 08:32 AM
fla-tls's Avatar
On the way!
Ouch - sorry to hear that, man. What do you plan on doing now? I hope there's no permanent damage to your engine.
Old Oct 3, 2004 | 09:35 AM
SCTL-SS's Avatar
13.68 @ 102.56
I'm hoping that the harness to the E-manage will straighten things out. The car, believe it or not actually drove OK on the way home. It's as if the car performs better at part throttle then it does at full, which just may be the case where it doesn't have to pull timing. I'll post results after the harness install.
BTW: hope to see you again at the track.
Old Oct 3, 2004 | 10:27 AM
fla-tls's Avatar
On the way!
I definitely want to go once it get's down around 70 or so!
Old Oct 3, 2004 | 09:58 PM
no offense ive heard w really bad things abuot hondas and emanage .. dont ask me what but simply that they dont like eachother... all my friends with them said they actualyl lost hp with the emanage
Old Oct 3, 2004 | 10:11 PM
You should really get rid of the E-Manage and get the APEXi VTEC controller. A kid on my campus has one on his S2000.. I've yet to ask him about the gains, but his car sounds pretty quick.
Old Oct 4, 2004 | 10:15 AM
SCTL-SS's Avatar
13.68 @ 102.56
For this aplication(SC and Turbo CLs) the E-manage has proven to be very effective. The Apexi controler seems to be somewhat limited in this case - ignition timing, expanding pulse with on injectors, adding extra injectors, etc..
Old Oct 4, 2004 | 03:17 PM
patrick's Avatar
Contact Scalbert for some technical help. I'm sure he'll be able to figure out what went wrong with your setup. Good luck to you!
Old Oct 4, 2004 | 03:39 PM
SCTL-SS's Avatar
13.68 @ 102.56
I talked with him this morning and he is sending me the harness for the E-manage. Hopefully that will do the job. I'll post new results as I can.
Old Oct 4, 2004 | 03:40 PM
fla-tls's Avatar
On the way!
Hey SCTL-SS, have you ever dyno'd the car? I'd love to see what #'s it puts out.
Old Oct 4, 2004 | 03:50 PM
SCTL-SS's Avatar
13.68 @ 102.56
I do have a dyno but it is not current. The last dyno was 265hp 232tq and that was pre UR pulleys, B-pipe and I/C. Once the car is tuned and I have the harness I'll have it done again.
Where guessing maybe in the 320-335 range at the wheels.
Old Oct 4, 2004 | 03:52 PM
fla-tls's Avatar
On the way!
Sweet - it's interesting to not that all of that work got the WHP numbers back to what they were supposed to be at the crank.
It really illustrates how much HP is lost in the drivetrain.
Old Dec 9, 2004 | 07:29 AM
sohfast94's Avatar
Normally the drivetrain accounts for about ~12-18 percent to the tire.
Old Dec 9, 2004 | 07:42 AM
fla-tls's Avatar
On the way!
Man - this thread got pulled up again???
Old Dec 9, 2004 | 08:15 AM
sc354's Avatar
Just wondering...how does adding ice to the resovoir (I assume the intake box) improve your numbers? Does it cool the air passing through thus putting colder air in your engine, which TL's tend to like?
I know that mine loves it when it's below 0 outside. With dry roads and below 30 degrees fahrenheit, the TL roars when under WOT. Gotta love VTEC.
Old Dec 9, 2004 | 09:05 AM
fsttyms1's Avatar
ice helps cool the engine and the air into the engine. a cooler engine will make more hp than a hot one. as a engine sits off the temp will rise before it goes down. icing helps to keep it from spiking and lowers it
Old Dec 9, 2004 | 02:52 PM
lol
Old Dec 9, 2004 | 02:53 PM
screw that .... dry ice duct tapped do the intercooler or taped in front of the air filter works wonders bwahaha
Old Dec 9, 2004 | 03:48 PM
REDLINEN's Avatar
Missing my Acura's
did ya ever run again?
Old Dec 10, 2004 | 05:25 AM
SCTL-SS's Avatar
13.68 @ 102.56
If your referring to me no. It's still in the shop.
Old Dec 10, 2004 | 11:24 AM
r10apple's Avatar
lover and fighter
That totally sucks. I remember seeing you and your car running 13.9's easily in Gainesville (or was that Ocala) last Spring...
Old Dec 10, 2004 | 12:33 PM
SCTL-SS's Avatar
13.68 @ 102.56
It was SpeedWorld in Orlando......ah those were the 'good old days'
BTW it is good to hear from you - newlywed right??
Old Dec 11, 2004 | 09:34 AM
fla-tls's Avatar
On the way!
I remember being there as well. Hi fellas!
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
steve
Sep 30, 2015 09:23 PM
Acura604
Sep 28, 2015 12:24 PM
