Gap in Rear Factory Bodykit
Old Sep 11, 2001 | 01:40 PM
TL4K's Avatar
5th Gear
Question Gap in Rear Factory Bodykit
Just bought my TL-S with the Acura bodykit and spoiler. :p
The rear skirt doesn't seem to fit right. There is a significant gap between the rear skirt corners and the car body. Does anybody else have this gap?
I'm thinking about taking the car back in to either get the rear skirt adjusted or a new piece put on.
Old Sep 11, 2001 | 04:16 PM
tdoh's Avatar
Yep, I have the same problem too. The dealer tried to adjust it as much as he could but to no avail; said the mold used to create the rear skirts probably weren't spec'd out properly. One other person with the same problem was a bit luckier as there was a bit more space to realign the mounting holes so that the skirt would fit flush with the rear bumper.
As much as I would have liked the dealer to have fixed the problem in its entirety, I'm not gonna lose any sleep over the small gap--you can't see it unless you're looking right up to the bumper corner.
Tony
Old Sep 11, 2001 | 08:54 PM
lilboykorea's Avatar
take it back to the dealer and complain...u paid for it....and the dealer probably did the install...
Old Sep 11, 2001 | 09:50 PM
RedLined's Avatar
I noticed this same problem after I installed mine. It seems the corners bowed out after installing the top screw in the wheel well behind the rear wheel. I think if you remove the screw, make the bodykit flush with the bumper, drill a pilot hole, and then use a spacer of some sort (a small washer or 2) before re-installing the screw, that should do the trick.
Or it may be that a spacer isn't necessary and that it's just that a new hole needs to be made.
I haven't had a chance to fix mine but that's what I plan to do. But if the dealer installed it, get them to fix it.
Old Sep 12, 2001 | 12:11 PM
mikegunnz's Avatar
Same here, the rear body kit just doesn't seem to fit right at the corners near the wheel wells. It's not too bad though so I'm not worried.
Old Sep 12, 2001 | 12:44 PM
yee's Avatar
yee
sorry that you've noticed it too...
I too have noticed the problem...in fact, someone here once called Acura and they said that they've notice the mis-fit as well...but there's nothing they can do about it...
I guess we'll just have to suck it up..
Old Sep 12, 2001 | 03:10 PM
TL4K's Avatar
5th Gear
I'm taking my car into the dealer on Friday and I'll see what they say. Thanks for the input.
Old Sep 12, 2001 | 05:53 PM
Jens
Guest
Posts: n/a
I have seen this problem several times now and it seems that some kits are simply molded in such a fashion that causes it.One thing I have found that may help in some instances is this.Loosening all the fasteners first then add a few spacers/washers where the rear kit is attached to the wheel opening.This is the spot where screws are used.Place the washers between the bumper cover and the aerokit.you may haver to use longer screws to reattach the kit to the bumper cover.Then starting at the center of the car work your way around to the sides off the car tightening the fasteners as you go.Sometimes slightly enlarging the mounting holes in the rear aero part is helpful and will allow a better fit,The only donside to this is that where the kit is attached inb the wheel opening there is now a gap with spacres/washers visible.Use some body colored touch up etc to cover this up as much as possible.Jens
oyayjoe
Jan 1, 2019 10:17 PM
BoricuaTL
Apr 8, 2016 01:08 PM
scionxb3003
Oct 2, 2015 05:50 PM
Sep 15, 2015 06:44 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
