Fuse ???????????????
Old Jan 17, 2004 | 05:04 PM
Mr Zipps's Avatar
What fuse on the passenger side becomes hot with the ignition... Im wiring my XM radio.. I had it wired to the radio but that is hot all the time...
Old Jan 17, 2004 | 06:55 PM
`ill*tl's Avatar
When do you want it to be hot? .. when our keys are in our ignition on I or II?
Old Jan 17, 2004 | 10:07 PM
Tom Blasing's Avatar
is the Mighty Favog
Try numbers 1, 2, 11 or 12. Those are for the moonroof motor and selenoids.
Just be sure I would take a noid light (looks like an ice pick with a wire coming out of the handle) and test for voltage with the key on and off. I did the same thing when I hardwired the V1..
Old Jan 17, 2004 | 10:33 PM
jpadilla's Avatar
For God's sake ... don't tap into a fuse slot that is already designated for something else. Use a volt meter or as suggested a 'noid' light and find a slot that is not being used that is hot with key on and NOT hot with key off. Otherwise run a dedicated wire from the battery if u dont already have one (such as for amps etc) and use a bosch relay to swith on/off with the ignition.
Old Jan 17, 2004 | 10:43 PM
`ill*tl's Avatar
I don't think a XM radio can do much harm. But I guess if you really want to be safe. :p
Old Jan 18, 2004 | 12:15 PM
Mr Zipps's Avatar
The XM radio runs off of 6v its not going to do that much damage....
Tom Blasing -- Thanks for the info....
Old Jan 18, 2004 | 12:37 PM
hzm82's Avatar
Why don't you use the accessories sockets on the opps. side of the driver's fuse box? I'm not sure but i believe #1 comes on with ignitions. (I do know that #3 power on with parking light, I have my indiglo gauges wired to it), (#5 is constant power, I have my shock sensors attched to it).
Acura604
20
Aug 5, 2017 12:55 AM
Skirmich
Oct 1, 2015 12:59 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
ripit
Sep 26, 2015 06:19 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
