Fuel Gauge AGAIN??????
I filled up my tank last week,the fuel gauge only went to 3/4 full. then went up, then down, kept fluctuating.. I went this weekend to refill, at this point, the low fuel light was glowing for some time, the gauge was on the line just above the E(mpty), and I only filled 14.5 gallons! Either they engineered the float sensor terribly that it never gives u a correct reading, or somebody's f#$ked up... and the fuel gauge was replaced under warranty last august..Oh yeah, it filled up again 3/4 a tank, then went up a lttle bit after 20 minutes, then all the way p, now it sank back down to 3/4 tank again, and NO, im not parked on an incline!
Ed
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Ed
Ed
Pics of my TL
Shoofin, I used to think my fuel gauage was broken when I after I filled up a full tank of gas. It would not even go to the F when it was topped off. I used to keep my car's ignition on with the car off on II and when I stopped doing that, it goes up all the way now. Try it once and see if it works if you already haven't.
Rosh
Rosh
I agree. I filled up my tank with the car still on after I had been on Empty for a while. The needle never returned to full untill I got it back to E and shut the car off BEFORE filling the tank. No problems anymore.
Somebody once told me its not good to "top off" the tank b/c it messes up the float sensor. but again just something i heard.
2001 Nighthawk Black Pearl TL
- Inspire tailights
- Weapon-R hyper intake
- Burlwood shift knob
- Razo carbon fiber pedals
- Inspire fog light switch (no fogs yet)
that's odd. I've never had any fuel gauge problems with my car. The gas light does seem to come on when I still have over 3 gallons of gas still left in the tank, which seems over cautious to me.
I see no problem with filling gas with the key in the II position as long as the engine is not on. If you leave the engine on while filling, that could be a big problem.
'01 TL with Navi
Naples Gold Metallic
Everything is stock for the moment
except for a big plush teddy bear in the back seat.
'01 TL with Navi
mine reads about 7/8 when i fill it all the way up. I can get it to read F if I turn the key on and off a few times, but there is definitely a prob with the gauge...I just dont feel like going back to Acura for it...very annoying though, but as long as I fill up everytime it wont be an issue for me.
~!ed
~!ed
S/C'd Accord Coming Soon!
I had to have the float sensor in the gas tank replaced in my 2000 Accord V6. But get this, my needle worked, it was only the low fuel light that didn't work! When my car started cutting out on me I knew I had problem. Fortunately I made it to a gas station before the car died. I put 16.5 gallons of gas in my tank without the low fuel light EVER coming on. Hehehe... I think the float worked fine up high, but for some reason it got stuck when it got a certain point and wouldn't go any lower.
It was replaced under warranty and didn't cost me anything.
Brian =B-)
2000 Accord LX V6 Sedan White - 3,310 lbs w/ driver - 170HP & 160ft/lbs
- Koni Yellows & Eibach Pro-Kit (1.5" drop)
- Red AEM Short RAM Intake (8-10hp & 5-6 ft/lbs gain on a DynoJet)
- Red AEM Tru Power Pulleys (10hp @ 5,600rpms & 11ft/lbs @ 4,600rpms gain on a DynoJet)
- 15.45 @ 88.8mph (Track) [with AEM intake/pulleys] 0-60mph 7.2 sec (G-Tech) [with intake/pulleys]
Brian =B-)
I always keep the car running when i fill up and no problems with the fuel gauge.
- Inspire tailights
Hey some people think its a contest to see how much gas they can $qeeze into their tanks. That is bad for the gas tank too!!! Do not do that, when filling up stop pumpin when the pump stops...
Shyne--Pumpin gas from my a$$ onto the overpass ...
Why would anyone ever leave their engine while pumping gas? I was always told to turn off my engine when refueling. Could be something about releasing pressure in the fuel tank,not sure, just know its not good.
99' Taffeta white TL
"It Aint Real Bass unless It hurts just to sit in the Car"
Fosgate Power 800a2
Two 10" Hx2
E750s Lanzar Preamp
Fosgate Power 800a2
Two 10" Hx2
E750s Lanzar Preamp
joflewbyu2
10-08-2015 11:16 AM
