FRAM Ultra Synthetic Oil Filter
So I started using the new FRAM Ultra Synthetic Oil Filter early 2014. All I have to say is "WOW!". I never seen any oil filter do as good as this. This is the 2nd time with this new filter.
These are photos of the oil after 7000 Kilometers. Usually the oil is black and smells really bad. The oil as you can see here is still clean, and smells new. It looks like a light red colour. No hint of black. Sorry about the blurry photos.
I was about to change the oil but I'll wait till the end of the month. FRAM got it right!
why does your oil get dirty so fast? you need to address that question which probably involves a dirty PCV and clogged egr system inside intake manifold which are forcing exhaust type gasses back into crankcase at increased levels = dirty oil in 3000 MILES!
Other filters and regular oil stay fairly clean and a nice amber color
What are you running that is red? trans fluid! or actual red oil ?? something fully synthetic I am guessing= that filter being made to work with that type oil
next oil change: add 1/2 can seafoam to oil and drive 30 minutes or more
Best to install new cheap filter and drive 100-200 Miles to get fullest effect and capture the crud, then change oil and filter with oil warm from 15 minute drive
I have used BOSCH, K&N GOLD, and the standard Honda filters. K&N was the best filter I have used. But it didn't perform as well as this new FRAM filter.
I am using Castrol Syntec (EDGE in some countries) 5W-30. I stuck with the Castrol becasue it has given me great fuel economy.
I am going to get a new car in 2015 or when this TL dies. So I am not going to do those tasks 01tl4tl mentioned.
That is surprising to me because i know Fram always made cheaper quality filters compared to other brands (i always avoided using Fram) but i will have to look into this filter a little more closely.
I say stay away from the cheapest FRAM filter. This one looks good.
There's a video on Youtube showing that the new Honda/Acura filters will be made by FRAM. It'll be made like the standard FRAM filter and it won't be like the FRAM Ultra Synthetic.
What I am going to do is post up photos of my oil every 1000 kilometers. I am almost at 8000k on the same oil.
Castrol Syntec (EDGE) 5W-30. I don't know why its that colour.
It is $13.99 Canadian for it. But I got it on sale for $9.99 Cdn.
what color is the oil when it goes in?
skirm: do as fsttyms1 says and get the oil analysis done at 7500 with the extra $10 test for remaining life expectancy, which is often based on the additives wearing out- more than the oils death
blacktire- kept up, the TL will easily go 300,000 USA MILES/ 500,000KM
DO change your PCV on top of valve rear valve cover, its 10 bucks and if you are blowing oil in the engine that part will get clogged= not able to release internal engine pressures= cause the demise of said engine by blowing out the rear main OIL seal!!
for others- using seafoam in fuel and oil as well as the new pcv are solid investments in mpg
I stayed away from FRAM because all those Youtube videos showing the filter failing. My thought are that these "failed" filters have been damaged by the user and then put on video to show how bad they are.
As well many people engines who have failed are blaming FRAM oil filters. How do we know they didn't do anything stupid to the vehicle?
I read somewhere that Fram has spent a lot of $$ the last few years trying to change the perceptions out there. Some of their newer higher priced filters are rated pretty high I believe.
I imagine that some of the issues (whether truly the fault of the filter or otherwise) was a byproduct of them probably selling the most filters in the industry through the years. The more product you have out there the higher the chance of having some issues along the way I suppose. I used to use the standard Fram filters in the 80s and never had a problem. Now I usually use the Puralotor pure One or Denso filters
I've been using Mobil 1 Synthetic with the FRAM XG3593A for years now; 7K between changes. I also had used the K&N HP-1004 and the Mobil 1 filters for a long time.
Have 277K on the car and no sludge when looking in the valve cover.
Fram is the cheapest of the bunch at Walmart for ~$8 and is a good buy.
Always check the box; I find a lot of unsavory people swap the cheaper Fram filter into the box to save $3 - very annoying going though a shelf of five boxes and they are all the wrong one inside!
The following 3 users liked this post by justnspace:
LOL...I had a extra dipstick I ordered a while back. Just dipped the other in a fresh bottle of oil and held them both up to the camera.
BTW...I do 70% city traffic. The other 30% is highway driving.
I still cannot believe it myself. I hope some other people start using it and post up results too.
justnspace (10-27-2014)
justnspace (10-28-2014)
the real info will be in the filter when cut open after replacement
unrolling and seeing whats captured- how much blockage appears to be happening
is the real info..that and mass spectrograph the oil to see amount of crud in it
what brand oil are you using that's red?
or it was clear like the new oil in bottle to start, and turned red?
Fram's new filter or crabs ?
Fram's trying to regain consumer confidence by offering "premium" products.
Using Castrol EDGE 5W-30. I have been using Castrol EDGE for awhile with other filters and the oil would be black as night by 6000 kilometers.
I assume FRAM added special filter paper that is causing the oil to go red?
rcs86
08-02-2016 06:52 PM
lanechanger
10-13-2015 10:56 AM
