Four Windows Stuck?
Four Windows Stuck?
Was riding to school today then went back home and everything was fine....went back to school and when I was coming back all four windows wouldnt go down. Sunroof works fine, and so does everything else. Fuse? If u guys/gals think its the fuse where is this fuse located? Thanks TL Gods.
COTM Coordinator
The fuse is gonna be located in 1 of 3 spots:
Drivers side fuse panel
Passenger side fuse panel
Engine compartment fuse box
My guess would be passenger side fuse box.
open passenger side door. on the side panel you will see a cover that indates the fuse box read on the cover and it should point you to which one is the fuse
i knew where all the fuses were just didnt know the exact fuse for the windows but anyways this might sound weird to you guys but the next day i turned on the car and windows went down no problem....the following day after that i get to work and park. While the car was on and in Park, i start putting my drivers window up and it stops midway. While its still on i try putting down all the other windows and nothing (that Master On/Off window switch did nothin, i never touch it). I turn off the car, turn it back on and they all work fine. Since that day its been workin fine. Let me also note that it was raining ALOT and kinda hard when all that was happening. Perhaps it has to do with some water seeping into the window switches themselves on my drivers door when i had my windows cracked a lil while drivin to let the smoke out.
there could be a few things that could be at fault.
do have aftermarket speakers installed? if so check for clearance. with it warming up it could be causing the "circuit breaker" that our windows circuits have to be acting up.
is there anything else not working correctly? anything that the bcm would control? the switches are controlled through data lines that run through the bcm as well.
last resort would be the switches themselves. they could be dirty or whatnot. i dont know if i have the windows circuit diagram anymore available, so im unsure but it could be your master switch itself. some window circuits run through a master switch and if not connected or acting up could cause weird things to happen.
do the windows role down at the switch at each door?
xsilverhawkx
09-28-2015 06:51 PM
