Found open wiring in the trunk.
Old Oct 24, 2014 | 12:13 AM
JIGS's Avatar
Acura 3.2 TL 2001.
i need some help to figure out where to connect this wire, which i found lying open in the trunk. i was installing back up camera, and had to open the trunk liner behind both the back lights to access the reverse light. when i opened the left side liner, i found that there are 4 wires joined together, but are floating and not connected anywhere (circled red in the photo below). i did not see any bolt, where it should be connected. there is a hole besides it, where i can put a screw (circled green in the photo below), but i am not sure if that should be connected there. i need to confirm weather it should be connected to the body or it was purposely left disconnected.
If anyone who has a 2001 Acura TL, pleaae check and confirm where this set of wires should be connected.
Old Oct 24, 2014 | 09:43 AM
fsttyms1's Avatar
I just looked at mine and it is attached where your green circle is.
Old Oct 24, 2014 | 09:45 AM
Sand the paint down first!
looks like some one removed that ground wire stack to paint!
sand the paint down where your green circle is.
metal on metal contact is best for grounds!
Old Oct 24, 2014 | 10:36 AM
JIGS's Avatar
Thanks for your prompt response guys.
I wonder how the car was running all these days, without any issues.
Looks like it was never connected anywhere.
It was sheer luck that i found this wire open, while installing the rear view camera.
I will sand it and then connect the wires to that hole.
Old Oct 24, 2014 | 06:04 PM
Slowpoke842's Avatar
Subaru Guy
Are you the original owner? The car might have been repainted after a collision and it wasn't reconnected.
Old Oct 24, 2014 | 06:13 PM
it looks to be painted VERY well.
as this car is almost 14 years old, I didnt expect the OP to be the original owner.
I would be concerned if that area looked like crap.
but it doesnt.
one couldnt tell that it was repainted, except that we know that grounds are supposed to be bare metal.
Old Oct 24, 2014 | 07:01 PM
3.2TLc's Avatar
It's possible that the wiring was left dangling from the factory assembly line.
Old Oct 24, 2014 | 08:19 PM
Aman's Avatar
Your Friendly Canadian
I would be surprised if the car lasted 14 years with that disconnected ground not causing problems.
Old Oct 25, 2014 | 06:30 PM
3.2TLc's Avatar
Wink Original owner ???
If not the original owner, than anything is possible.
How long have ya owned the car and have ya had any problems what-so-ever since purchasing the car ?
Old Oct 25, 2014 | 10:05 PM
Subaru Guy
but it doesnt.
Factories rarely paint that well when they know it will be behind trim. That's why I suspect it's repainted. No worries. As mentioned, sand it down / clean the threads and the grounds should be good.
And we've owned our 2003 Gen 2 TL since new. Motor's perfect, body is in good condition... why not?
Old Oct 25, 2014 | 10:48 PM
3.2TLc's Avatar
Wink Possible repaint......
Factories rarely paint that well when they know it will be behind trim. That's why I suspect it's repainted. ... why not?
Yeah, I've personally seen some scuzzy paint on the "unseen" areas from the factory, no doubt about it.
But, are ya saying that the bodyshops are doing better paintwork than the factory ??? If so, they would be more careful of attention to detail.....such as the ground wire.
Old Oct 26, 2014 | 09:59 PM
01tl4tl's Avatar
the painter and the far lower paid person doing the re-assembly of cars in body shops = YIKES
Not the same level of skills, knowledge or caring
Slap that shite together,, so what if its missing the screws that hold the bumper cover in place,,,customer wont notice, they are idiots too,,, right!?
Old Oct 27, 2014 | 12:09 AM
wng's Avatar
wng
Originally Posted by JIGS
I wonder how the car was running all these days, without any issues...
It's possible that the trunk liner pressed it against the sheet metal enough to ground it. It's not a great connection, because it's not bare metal and only held on there enough by the pressure from the liner, but it might have been enough.
Old Oct 27, 2014 | 09:55 AM
JIGS's Avatar
Thanks for the concern guys.
I am not the original owner, but there was no collision reported in carfax when i bought it (i dont know how accurate that can be)
Old Oct 27, 2014 | 09:58 AM
JIGS's Avatar
I just bought this car a few months back for my wife, as she is still learning to drive. but looks in good condition.
No problems since purchase. everything is smooth.
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
MyKids&Cars
Oct 13, 2015 11:44 PM
yvr_tsx
Sep 15, 2015 01:14 PM
TSX 09
Sep 10, 2015 10:21 AM
