Flushing my tranny?
Old Jul 23, 2014 | 10:47 PM
Kevin_727's Avatar
Flushing my tranny?
Long story short, I tried to flush my tranny today and couldn't crack the drain bolt. Any suggestions on how to crack the bolt? I already tried asking someone stronger than I am.
Old Jul 23, 2014 | 10:53 PM
dirko's Avatar
Hi Ho: It's always a question of what tool you're using. Since a 3/8 socket extension is what fits, why don't you try a short 3/8 impact extension with an adapter for your 1/2 inch impact wrench. My old dad always told me that "get a bigger hammer" is ok, but for bolts an impact is always better than a longer breaker bar.
Old Jul 23, 2014 | 10:58 PM
Kevin_727's Avatar
I was using an Autocraft 3/8 ratchet, Any alternatives to buying an impact wrench?
Old Jul 23, 2014 | 11:04 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Was the engine Hot or cold ? Must be hot.
This is what worked for me, I kicked the ratchet with my foot a few times.
Just make sure you're using good tools.
Old Jul 23, 2014 | 11:15 PM
Kevin_727's Avatar
My engine was cool when I tried. I'll try again tomorrow when it's hot
Old Jul 23, 2014 | 11:40 PM
01tl4tl's Avatar
work smarter not harder
spray some wd or similar product on threads and let sit overnight if possible, a few minutes works but more time is better- respray before working on it
Use a BREAKER BAR, a ratchet cant stand the stress on small teeth of its gear system!
a breaker bar has a 3/8 socket end that only flips 180 degrees at end of tool = strong and made to be punished and stressed
Then you can slip a larger diameter and longer metal pipe over the breaker bar and leverage it from 3 feet away, a push with your foot to the bar etc
sometimes applying pressure tap, as if slightly tightening the stuck plug or bolt- will break the crud bond that has formed
then it loosens right up
Important, you will probably have to break the filler hole bolt open too, breaker bar and socket will help there ,,prespray with wd
do that first, before draining
yes you can refill thru small diameter dipstick tube but much slower than actual filler hole
Old Jul 23, 2014 | 11:44 PM
01tl4tl's Avatar
confirm you are using Honda DW-1 atf? not some acura compatible stuff
the spec torque on the drain plug is 29 foot pounds, same as the engine oil drain plug
Old Jul 24, 2014 | 07:12 AM
Nicks2001tl's Avatar
+1 on the extension and WD-40 or PB blaster. I also kicked my wrench when I did it the first time, the bolt was super stuck.
An extendable ratchet will work wonders and great to use for the rest of the car,
Old Jul 24, 2014 | 09:42 AM
01tl4tl's Avatar
BUT that has the same issue of putting way too much stress of the gear system the ratchet uses, exceed its limits-bust the gear and you trash the tool, and may throw your knee out in a big way for good measure!
a small investment in the proper tool- a breaker bar = for breaking things loose, is the way to go
You will use it over and over
Old Jul 24, 2014 | 03:30 PM
3.2TLc's Avatar
^^^ Yeah, agree on using the proper tool for the job......but, when folks have a lifetime warranty on their tools, they tend to abuse them from time to time.....ya know !!!
Old Jul 25, 2014 | 10:14 AM
01tl4tl's Avatar
oh I know about busting cheap tools when applying way too much load on them
how do you think I know you can blow out a knee when pushing with leg and that gear breaks,,,, proper tools were purchased soon after the cast was removed
everyone in America knows about HFT= Harbor Freight Tools right? they are everywhere, decent enough tools and budget prices, for basic socket sets, prybars and a breaker bar they are fine www.harborfreight.com
Old Jul 25, 2014 | 10:29 AM
acrdr's Avatar
There is a easier way to brake the drain and fill bolts loose
Your have to tighten the bolts with one fast movement
That will crush the crush washers more and the try to loosen the bolt . It work
The bolt should only move about a 1/4 of turn when tightening it before loosening it
Pham Alvan
May 18, 2021 06:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
Pham Alvan
Mar 16, 2016 09:17 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
