Filter advice?
Old Apr 18, 2004 | 08:28 PM
Toby_TL's Avatar
Filter advice?
Right now I am stock on my '00 TLP ...but I am thinking replace stock air filter with k&n one and remove Stock Airbox resonator . Will it make any difference or improvment?. any suggestion or other recommandation?......P.S. if i dont remove resonator and whats resonator do anyway..sorry newbie :toothless
Old Apr 18, 2004 | 09:16 PM
fsttyms1's Avatar
yea i would recomend getting a K&N and removing the resonator. the biggest improvement will be sound but you will gain a few hp.
the resonator is exactly that, it changes (muffles the sound)
Old Apr 18, 2004 | 09:55 PM
ou sig's Avatar
Boomer SOONER
link to remove the resonator
http://www.abunchofcars.com/diy_page.../resonator.htm
very nice improvement in sound when you hit the VTEC range
Old Apr 19, 2004 | 12:46 PM
JGsTL-S's Avatar
hmmm, think I need to remove that thing to then cuz I have the comptech drop in and it sounds like it breathes better but never really felt like i got too much out of it except never buying a new filter.
Old Apr 19, 2004 | 12:58 PM
LargeOne's Avatar
Just agree and go away...
I put in the drop in K&N Air filter and removed the big resonator and I am really feeling the difference when I accellerate hard... you will feel it too (not to mention it sounds sweet!!!)
LargeOne
Old Apr 19, 2004 | 01:03 PM
ResidualFreedom's Avatar
2400 Watts in a TL...Why?
LargeOne
I second that
Old Apr 19, 2004 | 01:10 PM
Elementz's Avatar
Will this mod change the sound from the outside of the car too?
Also, all u do is remove the resonator? You dont have to hook anything back in its place?
And, what does a resonator actually do anyway?
Old Apr 19, 2004 | 01:27 PM
ou sig's Avatar
Boomer SOONER
do a search on it and you will find out more than you want to know, all it does is act like a muffler for your intake - quiet. serves no other purpose.
Old Apr 19, 2004 | 04:18 PM
fsttyms1's Avatar
yup louder out side the car (good loud)
the resonator muffles the sound
nope just remove the big ugly nasty restrictive thing!
Old Apr 20, 2004 | 12:56 AM
Seotaji's Avatar
i drove a tl with a k&n and one without, both had resonators removed.
all it will do is let in more dirt since it doesn't have as much filter area as stock, plus the gauze is a crappy filter.. you won't gain MPG, power, etc...
stock paper air filters flow almost as well as the gauze variety and filter better.
that's if you care about filtering, if not, have fun
Old Apr 20, 2004 | 12:50 PM
ou sig's Avatar
Boomer SOONER
hmmm its interesting that I havent heard of anyones engine having problems linked to having a K&N filter....
Old Apr 20, 2004 | 01:12 PM
JGsTL-S's Avatar
only problem I have experienced with a K&N type filter is that it lets in water easier than the paper. I have one in my truck and in mud or high water situations the K&N lets the water right into the intake. Paper gives a little better barrier in that scenario. So I guess if you are in that type of situation with the car...go paper. Other than that, a properly maintained mesh will do the trick quite well.
Old Apr 20, 2004 | 01:42 PM
ou sig's Avatar
Boomer SOONER
Its obvious that to get better filtering you will have to sacrifice some air flow and vis versa. The filtering that you are loosing with a K&N or any other "high flow" filter - K&N, Comptech, the CAI filters... is negligable at most, but any filter that gets wet will most likely let some moisture in - just depends on how much and how hard you are pushing the engine.
Old Apr 20, 2004 | 02:03 PM
fsttyms1's Avatar
i have been running this set up for 140k and have not had a single problem with water and dirt(and i went as far as to cut the bottom side of the air box off. the k&n in my expierencies filter alot better that paper, which when once wet loose alot of there ability to filter and dont last long once wet.
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
soupi
14
Nov 15, 2015 11:15 AM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
