Filling up issue
Old Jan 30, 2014 | 06:58 AM
BoriTL's Avatar
Filling up issue
everytime i fill up pump stops as if it was full but its not, let it settle for a sec and i can start again and than stops again, process continues until full. Extremely annoying, how can i fix??
Old Jan 30, 2014 | 08:00 AM
Barry95's Avatar
Who needs mods
thats just the pump dont push the nozzle all the way in
Old Jan 30, 2014 | 08:15 AM
dreem1er's Avatar
deal with it
Old Jan 30, 2014 | 09:46 AM
Nicks2001tl's Avatar
Does that happen at all gas stations or just one in particular?
Old Jan 30, 2014 | 10:46 AM
BoriTL's Avatar
Nope regardless of how far, still stops. i can see the gas coming to the top of the neck as if it was full but its a constant process to let it go down and than start filling up again. took me like 10 mins to fill up this morning from empty.
Old Feb 4, 2014 | 09:53 PM
01tl4tl's Avatar
not supposed to go all the way to the top!
see owner manual and threads on damage to the charcoal filter in the fuel vent system
when overfilling tank sends liquid to a vapor system--ooops
if the fuel light just came on its got about 3 gal left in tank
14 is the number to fill it from there
its not stopping at half tank right--just at full?
Old Feb 4, 2014 | 10:24 PM
HairyMonkey019's Avatar
once fuel light comes on, it's actually about 2.5 gallons left with 2 usable gallons until it stalls. I remember seeing the thread on this.
Old Feb 5, 2014 | 12:17 AM
ErickUa5's Avatar
Mr.Helpful Diagram
Here's a video to help you understand how the system works.
Sounds to me like its not able to displace the air while your filling up.
The Service Manual has a way to test all this equipment, Look in the EVAP section.
Old Feb 5, 2014 | 06:58 AM
BoriTL's Avatar
no it stops right away. gas light just happen to go on this time, but happens either way at any gas station. i could start pumping and first 5 secs is fine that the pump stops and you can see gas come up but i have to wait for it to settle than pump again and stops again, etc till filled.
Old Feb 5, 2014 | 07:25 AM
3.2TLc's Avatar
Try running a wire down through the fill tube.....maybe something is restricting the flow ? Is there any CEL codes for the EVAP system ?
Does it do this "stopping" always, rather or not when ya set the pump's nozzle for either auto or manual hand fill pressure at the gas pump ?
Old Feb 5, 2014 | 08:04 AM
RONE's Avatar
Don't put the nozzle 100% into the fill hole. Back it out ~1/2". Also, don't lock the handle on the pump into the fastest setting (usually have 3 settings). Try the middle setting.
Old Feb 5, 2014 | 03:33 PM
BoriTL's Avatar
No CEL, always stops no matter how fast, i wait for gas to settle for a sec and than start again, i've ran seafoam every fill up the past 3 times since the car was sitting for a couple months but even before than i remember it still doing it. The backing out 1/2in doesnt work, the only way i've gotten it to flow constantly is putting the pump nozzle upside down while filling up.
Old Feb 5, 2014 | 04:15 PM
TLer trash's Avatar
I haven't run into this on a honda yet, but on everything else, it's usually a vent valve, vent valve circuit, or mud or spider webs preventing venting. Other than that, any ex-wives, or girlfriends mad at you? That would be tampons in the filler neck.
Old Feb 5, 2014 | 05:33 PM
3.2TLc's Avatar
Thumbs up works when flipped over......
Originally Posted by BoriTL
always stops no matter how fast, the backing out 1/2in doesnt work, the only way i've gotten it to flow constantly is putting the pump nozzle upside down while filling up.
Hmmm, maybe your car is just wanting a new technique during the filling procedure.
Old Feb 6, 2014 | 06:55 AM
BoriTL's Avatar
lol hahahahaha things are good in the homefront.
Old Feb 6, 2014 | 05:36 PM
01tl4tl's Avatar
search threads on charcoal canister
could be source of problem,,at least something to cross of the list if ok
based on my TL is the amount of fill at fuel light I stated, max gallons added ever was 16.4
and it was still running
cycdaniel
Dec 17, 2019 10:58 AM
snorf
Nov 4, 2019 06:44 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
vbgregg
Sep 11, 2015 05:38 PM
