Fuel Injectors
Old Feb 4, 2014 | 10:13 AM
donsor's Avatar
Fuel Injectors
What's the best preventive maintenance to keep fuel injectors clean and minimize clogging up?
Old Feb 4, 2014 | 10:49 AM
^run premium fuel.
as premium fuel has cleaners and detergents in it.
cincinattlguy19's Avatar
06 NBP 6MT TL
Most would probably suggest Seafoam or some type of fuel injector cleaner
Old Feb 4, 2014 | 11:21 AM
however, that is not preventive maintenance.
Old Feb 4, 2014 | 11:45 AM
06 NBP 6MT TL
Very true justnspace; reading gets the best of me. Premium (93 octane here in Ohio) fuel would be the best preventative maintenance.
Old Feb 4, 2014 | 03:18 PM
Nicks2001tl's Avatar
^run premium fuel.
Seafoam has stronger cleaning propeeties than detergent added premium fuel. Seafoam is a cleaner that you add to the gas tank to combat moisture in the fuel lines, free clogged injectors but not to be used more than once or twice a year.
Old Feb 4, 2014 | 05:39 PM
3.2TLc's Avatar
Yeah, as mentioned previously.....use a quality brand of premium fuel,
and then perhaps adding a can of fuel system cleaner at spring and fall if you so desire.
Old Feb 4, 2014 | 09:32 PM
01tl4tl's Avatar
use tier 1 quality fuel - look up stations in your area--it has more cleaners in it to combat crud from the ethanol!
you can use seafoam more than 1-2 times a year but don't need to
Add 1 can to half a tank of fuel- drive normal,
trips over 30 minutes really help it work best
if first time doing cleaner- after 2 to 4 weeks and down to half to nearly full tank of untreated fuel, add another can seafoam
now good for a year
never hurt to do 1 can to just under half tank (8gal) midyear- at oil change
ck their site for lots of good accurate info and various methods
www.seafoamsales.com
we do not have to do the vac port method if you do the can to half tank twice as described above
it gets everything when done thru the gas (except throttle air plate in TB)
Old Feb 5, 2014 | 07:24 AM
but but you wouldnt have to clean it with seafoam if quality fuel is used.
Old Feb 5, 2014 | 07:34 AM
3.2TLc's Avatar
Hey Justnspace*, Santa's crabs are all better now....how 'bout a little Cupidcrabber for V-day ? Where's the love ?
A bit of Seafoam never hurts and helps to fight the Ethanol deposits within our fuel systems.
Ya know that it can't hurt anything to do a little extra PM protection from those pesky crab things and stuff !!!
Old Feb 5, 2014 | 07:41 AM
lol, i have no control over my avatar
Old Feb 5, 2014 | 08:13 AM
What!?
Old Feb 5, 2014 | 08:17 AM
What!?
lol, the moderators have full control over what you see to the left.
if i change it, i will be banned.
Old Feb 5, 2014 | 08:58 AM
a
<---------------------Speak of the devil.
Old Feb 5, 2014 | 11:00 AM
03blackbeast's Avatar
I would just get a bottle of Lucas Fuel Cleaner and use about 2 oz per full fill up. Works great and boosts fuel economy. I got 30 mpg going from Indy to St. Louis a few months ago at 70 mph. Pretty sweet and it keeps the injectors clean.
Old Feb 6, 2014 | 05:46 PM
01tl4tl's Avatar
lucas is a good product too, use at max strength and following the directions will help remove crud buildup, I used it for years but note its directions require a few bottles, equaling the cost of seafoam at $7-10 a can
the cleaners they sell in a 3 pack- just for fuel use- well it comes with 3 for a reason
the tier 1 brand gas HELPS clean crud and keep most of it under control when used for over 5000 miles
A half can of seafoam will remove crud from intake valves and piston tops instantly when done thru master vac port at TB
Done thru fuel it gets every part all the way to the cat, and cleans it too
the main point is ethanol fuel leaves behind way more crud than old school gas
we have serious clearance issues in the piston vave area
keeping carbon buildup to a minimum is in the cars best interest
My Honda bike requires use of fuel cleaner for that same zero clearance reason
Use something!- lucas- bg44 sfoam redline is good too but use something
Old Feb 6, 2014 | 05:52 PM
01tl4tl's Avatar
ck the websites for the product you like- there will be minimum and max per gal doseage listed
below a certain point its not giving effective cleaning = you are throwing money away, and above it max does no extra cleaning,,same waste
spend wildly on suspension and brakes, pinch pennies on fuel cleaner,,what a guy! (poking fun at self)
joflewbyu2
Aug 18, 2019 10:38 PM
LeVeL
Oct 18, 2015 04:19 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
