Express roll up for all windows?
Is there any way to rig an express roll-up for the passenger's side window. Better yet, all windows? I know the driver's window has some kind of safety feature in it, but I would not worry too much about having that feature on the other windows, since I am usually by myself. By the way, I do not want an aftermarket alarm.
DEI529 module.
Received 2,329 Likes
Originally Posted by teknoking
DEI529 module.
If thats what I think it is.. you can do it for all your windows for under 200 bucks.
you cant do it wiht teh factory set up. you will need aftermarket stuff (like dei)
Originally Posted by TLover8888
so, if i install the DEI modules, then i can have one-touch up/down with all 4 windows using the existing window switches on the doors, like in BMW's??
DEI529 module.
yes, up and down
i've learned that the DEI530 module has a problem of becoming faulty after a while. DEI has acknowledged the problem and is coming out with another module to replace it. (thanks to NYDesi80 for the info)
DEI530 and DEI529 are the same functions.... DEI529 is for 1 window up and down or 2 windows up or 2 windows down.... DEI530 is basically two DEI529 built into one. So for the entire setup with the UP function can use 1 DEI530 or 2 DEI529.
NO alarm needed.
NO alarm needed.
xsilverhawkx
09-28-2015 06:51 PM
