Engine/TCS Lights
Old Jan 8, 2004 | 08:45 AM
RobDDD's Avatar
Engine/TCS Lights
Yesterday I noticed that my Engine Malfunction & TCS Lights came on while driving home from work. I think the cold weather could have something to do with it. When I got home I turned off the car and restarted it and the TCS light did not come back on. However, the Engine light stayed on. I checked the manual and it stated that the Engine light indicates a problem with the emissions system and the light will not reset until the third driving trip if the problem has gone away. Has anyone had any experiences with something like this? Any thoughts?
Old Jan 8, 2004 | 09:21 AM
goldendragon576's Avatar
TL-S driver
mine turned on last night. I called Park Ave and he just told me to reset the light. Turn the car off, push and hold the trip and reset buttons down, while holding the buttons, turn your car on. Continue to hold until the maint req light goes off. The car runs fine, he told me that light turns on at 7500 mile regarless of when you do an oil change. Since I got a new tranny at 30,000 miles they never reset the light. Everything was done at 30k so it just turned on last night. I'm not too worried about it.
Old Jan 8, 2004 | 11:48 AM
RobDDD's Avatar
Its the Engine Malfunction Light......not the Maintenance Indicator Lamp.
Old Jan 8, 2004 | 01:13 PM
songoku's Avatar
BlingBling INSPIRE 32V
It's not just for the emission. It can be anything. Bring it back to the dealer or mechanic shop. You need OBD reader to pull the faulty code to find out what's wrong. Good luck.
Old Jan 8, 2004 | 06:41 PM
randomwalk101's Avatar
Hello genius,
The engine mal func light does not equate maintenance light..
Old Jan 8, 2004 | 06:47 PM
fsttyms1's Avatar
when those 2 lights came on on mine it had something to do with carbon build up in the manifold. i had the same situation with the lights. it took the dealer like less than an hour to fix
Old Jan 12, 2004 | 01:04 AM
Aydin's Avatar
Mine just came on too. I am gonna call the dealer tomorrow. Anyone know what the difference between the two lights are.. The engine malfunction and the one that comes on ever certain amount of kilometers. I don't know which one just came on. What do they look like?
Sorry for the stupid question.
Old Jan 12, 2004 | 11:15 AM
Bitium's Avatar
Retired MOD
Engine and TCS light together (transmission failure). sorry
Make sure you get a read out fromt the dealer. I think is code 721 or in the 700 series. it makes both the engine and TCS come on.
Old Jan 12, 2004 | 11:30 AM
RobDDD's Avatar
What are the warning signs of a transmission failure besides the lights? anything I should be looking for? Hopefully, if that is the problem, the extended warranty will apply to my car.
Old Jan 12, 2004 | 03:08 PM
songoku's Avatar
That's not the only reason. When I had both TCS & engine check light came on, it was just cylinder misfire.
Old Jan 12, 2004 | 03:14 PM
Bitium's Avatar
Retired MOD
True....but this just sounds like a transmission. I haven't had my engine misfire, but i have heard about it.
Old Jan 12, 2004 | 08:22 PM
VTEC's Avatar
i have that too, and i'm takin mine in 2morrow morning.
Old Jan 12, 2004 | 09:37 PM
RobDDD's Avatar
VTEC,
Let us know what they come up with.
Old Jan 13, 2004 | 12:33 PM
Aydin's Avatar
do you guys think its bad to drive for the check engine light on???
i have already driven like 300k with it on. I have an appointment on friday whcih is like probably anohter 400k by then.
Old Jan 14, 2004 | 12:44 PM
yitbos's Avatar
Exclamation From another post
http://www.acura-tl.com/forum/showth...061#post660061
I just had this problem fixed, EGR kit install
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
