Engine swap 02 TL
Old 05-09-2022, 11:52 PM
Keith johnson's Avatar
Engine swap 02 TL
I have a 02 Tl that I am doing a engine swap for 02 Tl type S engine do I need the ecu and the complete harness or I cam use my old harness
Old 05-14-2022, 10:32 PM
619rcr's Avatar
ecu and engine harness or at least the pigtails for both sides. i have a 2g auto harness for j32a2 if your int, but its not gonna be fully plug and play to a j32a1 chassis.
Old 05-15-2022, 12:07 PM
USAF Veteran
Saudade's Avatar
Better check to see if your ECU is tied to the key and security system (immobilizer). I believe it is. So you''ll have to get your keys programmed to the new ecu. Also the programmed VIN will change. The ecu's are either Federal or California emissions. You should make sure they match.
Old 08-05-2022, 09:02 PM
thanks the car is not california so most likley i would have to get the keys re programed ?
Old 08-05-2022, 09:05 PM
so i have the type S harness and ECU do i have to get the keys re programed to the ecu?
Old 08-05-2022, 10:50 PM
619rcr's Avatar
Yes. unless you want to do the ghetto immob chip removal and have the check engine light on permanently. it's a theft prevention device, so its there for a reason.
Old 08-20-2022, 04:15 AM
hello can anyone help i did a swap on my 01 acura TL to 02 TL type S engine i ran into a small problem, the harness to the outer throttle body that plug into those two other plugs is not on the harness that runs along the driver's side fender, does anyone have any information on how to wire up those two other plugs to the 2nd throttle body, thanks
Old 08-20-2022, 07:50 AM
619rcr's Avatar
sub to alldatadiy for a month and you'll find all the schematics and plug pinouts.
thinhthan
04-08-2016 01:02 AM
Victorm96TL
1G TL Performance Parts & Modifications
04-26-2013 07:08 PM
cspesu
03-14-2010 10:16 PM
L3wD
03-05-2009 06:39 PM
TLFROGY
03-02-2003 08:54 PM
Quick Reply: Engine swap 02 TL
