engine squel
Old Jan 15, 2007 | 06:50 AM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
engine squel
just curious if anyone has this/ noticed this. when im wot in 1st gear and shift to second right before the limiter my engine sqeals. its a short sqeal. it doesnt sound like a tire it sounds more like a belt. but i have been noticing this for a while and dont have any other issues with my belts or anything else?
Old Jan 15, 2007 | 09:33 AM
fsttyms1's Avatar
ive heard that a few times on mine. Especially when the shift is really firm/quick. If it only does that once and awhile and only under WOT while shifting there i wouldnt worry about it. If the belt starts making noise or it does it mor often then id look into a new belt and tensioner
Old Jan 15, 2007 | 09:58 PM
Rpappi's Avatar
and same it only does it under hard shift and no other time. its been doing it since i bought the car with 27k miles on it.
i just thought that i would ask. i have always figured it just because im shifting hard in high RPM's.
thanks
Old Jan 15, 2007 | 10:12 PM
fsttyms1's Avatar
i just think its the rpms drop so quick from the shift the belt cant slow down fast enough and squeals slightly
Old Jan 15, 2007 | 10:22 PM
BigLizard's Avatar
Moderator Alumnus
Sounds like the belts. Have them changed since they are pretty old...not so much worn but time probably has them cracked through all the seasons your TL has been through.
Old Jan 16, 2007 | 12:52 AM
Rpappi's Avatar
my TL really hasent been through seasons heated garage. and never driven. i checked them fairly often they look brand new. but it really doesnt bother me i just thought that i would ask.
Old Jan 16, 2007 | 01:47 AM
BigLizard's Avatar
Moderator Alumnus
Just replace them though. They are almost 8 years old.
Old Jan 16, 2007 | 01:54 AM
Rpappi's Avatar
ya when i get my pullies i will there is no point in doing right now when i have 4 months till i leave for 4-6 months then ill get my pulleys put on.
Old Jan 16, 2007 | 01:56 AM
BigLizard's Avatar
Moderator Alumnus
True...you suck...
going to the desert, I'm actually jealous.
Old Jan 16, 2007 | 02:04 AM
Rpappi's Avatar
i cant wait. im getting so tired of this place.
140 degrees here i come
Old Jan 16, 2007 | 02:09 AM
BigLizard's Avatar
Moderator Alumnus
You'll come back 20 pounds lighter or heavier depending on how much you plan on working out over there. Plus, it's not like you can fuck whatever you want over there. The most you'll get is skin rash from sexing up the sand.
Old Jan 16, 2007 | 04:23 AM
Rpappi's Avatar
ya i will take my sexual frustration out on the weights.
i worked out alot last time i was over there but i had a break in one of the bones in my arm so i could not do too much it got really bad in the end when i was moving up in the weights. 40lb curls killed the bones but they are better now. i dont gain or loose weight. just get cut.
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
