Engine mount suggest??
Old Aug 5, 2015 | 08:40 PM
hugous's Avatar
Question Engine mount suggest??
Hi guys, it's time to replace engine mounts for my TL 99. I found that I have many options:
- Go with OEM (hydraulic and vac) that maybe break again after 50k miles.
- Innovative choice (no vac) but I am not sure how long it last.
- Fill the mount with polyurethane. Can I use this method to fix current broken mounts? Or use it to improve new mounts performance?
Need you guys opinion cause I want to keep my TL as long as possible, thank you.
Old Aug 5, 2015 | 10:40 PM
Skirmich's Avatar
1.- Most obvious choice
2.- Cant tell
3.- It works both ways but you cant choose the firmness typically.
4.- Purchase poly mounts < BEST OPTION! MOST EXPENSIVE.
Old Aug 6, 2015 | 02:29 AM
hugous's Avatar
Thanks Skirmich, what branch do you recommend for poly mounts? I want to replace whole set of 3
Old Aug 6, 2015 | 03:44 AM
Skirmich's Avatar
I cant really comment about that as I never used pre-made poly mounts.. My own home made poly filled mounts have been working pretty darn well so far. I hope some could chime in with more info with the aftermarket poly mounts.
Old Aug 6, 2015 | 05:18 PM
hugous's Avatar
I just wonder if I want to fix my broken mount with poly, is it necessary to take out the mount for filling? Can I fill directly when they're still in place? Thanks.
Old Aug 6, 2015 | 05:26 PM
kevinf41's Avatar
I got Innovative mounts and they pretty good. I have no complaints
Old Aug 7, 2015 | 08:00 AM
knice's Avatar
Poly is your best bet but not for the front mount. Use a hydraulic for the front and poly for the rest. You're going to get added vibration in the steering wheel if you go with a non-hydraulic rear poly mount. Front hydraulic dampens a lot of the vibrations at idle -- I should know as I just switched a poly out with a hydraulic mount. Bought the car with all poly mounts but the idle vibration was just too much.
Old Aug 26, 2015 | 02:33 PM
hugous's Avatar
Thanks guys. I am debating between XLR8 vs Innovative mounts. Which one to go?
Old Aug 26, 2015 | 04:42 PM
ExcelerateRep's Avatar
Former Sponsor
Our XLR8 mounts are made with high quality U.S. grade steel and 62A or 75A polyurethane bushings. We have them available for $300 and we have them in stock and ready to ship out!
XLR8 Engine Mounts - Excelerate Performance - Japanese and European Performance Specialists!!
Old Aug 26, 2015 | 08:28 PM
hugous's Avatar
Any discount for Zine member? $300 includes shipping or not?
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
