E-break light on!
Old Oct 21, 2006 | 11:17 PM
BuLtL00's Avatar
E-break light on!
Hi guys i have a TL 00 i bought 2 months ago with 83k miles a i have notices that even after i disengage the e-break the light stays on until i drive for some time and then goes away.Sometimes comes back on after i pres my break pedal.I have no idea why this is happening,any input from u guys will be very apreciated.Thanx
Old Oct 21, 2006 | 11:21 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
either you have a bad sensor. or your cable is sticking and not completly releasing
Old Oct 21, 2006 | 11:29 PM
BuLtL00's Avatar
How do i fix that and what cable is stickin out on a e-brake never heard of it thanx.
Old Oct 22, 2006 | 01:09 AM
superfob's Avatar
Try looking at the sensor. It's on the brake fluid reservoir cap. Sometimes the float(light blue color) that goes up and down dependant on the level of brake fluid, gets stuck. Try pushing it up and down and see if it moves freely. I fiddled with mine and the light went away. Most people change the sensor since it's around twenty dollars. I'm going to wait until it comes back.
Old Oct 22, 2006 | 07:43 AM
bkzjimmy's Avatar
NiGhT rIdEr
and check ya fluid. this happened to me.
Old Oct 22, 2006 | 10:57 AM
Trackruner228's Avatar
Well I have the same problem but I always assumed because it was my rotors where warped. Can that cause the light to come on too?
Old Oct 22, 2006 | 11:00 AM
fsttyms1's Avatar
No
Old Oct 22, 2006 | 04:03 PM
BuLtL00's Avatar
thanks guys your input is greatly apreciated i'll see what i can do if not gotta spare the 20$.Laters
Old Oct 22, 2006 | 07:24 PM
OK what is this it in my case then. In the moringings when I go out and its cold my break light comes on usally goes off but sometimes stays on or like him it will come on when I break. Its only in the mornings when its cold out. If I go out to my car around noon its fine. I always assumed it was because my rotors are warped but apparently not.
Old Oct 22, 2006 | 07:40 PM
fsttyms1's Avatar
Most likely the master cyl brake cap. The flot is probably sticking a little or the fluid is a little low
Old Oct 22, 2006 | 07:42 PM
jimhas's Avatar
3rd Gear
There is also a "Brake Lamp" indicator in the dash under the "Brake" indicator. You should be clear which you are talking about.
In my case the "Brake Lamp" indicator came on. The manual says it means one of your brake bulbs is burned out. A bit unusual b/c I previously burned out two anf the light never came on. Well, this time was different. When going in to change the bulb I discovered the bulb receptacle was scorched. It looks like it shorted out. To make matters worse, the bulb was fused into the socket and broke off when I tried to remove it. Now it looks like I'll have to go to the dealer to get a new receptacle and wiring stub.
I guess I feel lucky that it did not catch fire.
Old Oct 22, 2006 | 10:52 PM
BuLtL00's Avatar
Its the "BRAKE" indicator that comes on...
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
