Driver's Axle Trouble
Old Jan 5, 2014 | 01:32 PM
Karanx7's Avatar
Unregistered Member
I was trying to install my driver's side axle, but couldn't get it to seat in all the way.
Unfortunately when trying to get it in, a small circular spring came out. I'm guessing it's part of the axle seal in the transmission case? If I replace the axle seal, will I be ok?
I ask this because I also found a similar spring on the crankshaft when I did my rear main seal, but the new rear main seal didn't seam to have one. Maybe it's normally inside the RMS, and I pushed it out when I removed the old RMS?
Old Jan 6, 2014 | 11:04 AM
Karanx7's Avatar
Unregistered Member
Whoops, it's not called an axle seal. It's the transmission output seal.
Anyone had to replace it? I'm having trouble finding the part number.
Old Jan 6, 2014 | 11:44 AM
fsttyms1's Avatar
Im 99.99% positive this is the one you need.
91205-P0X-005 OIL SEAL (40X56X9) (NOK)
Old Jan 6, 2014 | 07:53 PM
Karanx7's Avatar
Unregistered Member
I though that was it too, but I noticed that the parts diagram lists that only 1 is required for the car. Looking at the transmission, it looks like there is a seal on both sides of the output. One for each driveshaft.
Hmm, I guess I'll buy the seal and find out.
Old Jan 8, 2014 | 01:09 AM
Karanx7's Avatar
Unregistered Member
Yup, that was the seal. The new one came with the spring inside of it.
Finally clutch job is done. Car fought me every step of the way.
Old Jan 8, 2014 | 03:06 AM
Skirmich's Avatar
Yesss the Beast is Finally coming Alive Karanx??? That sexy Manual isn't an easy gal..
Old Jan 8, 2014 | 07:28 AM
3.2TLc's Avatar
So did ya get the tranny housing bolt holes to work ok ?
Old Jan 8, 2014 | 11:02 AM
Karanx7's Avatar
Unregistered Member
Yea, the shop that cleaned the threads did a really good job. He told me there aren't many threads left, but thankfully the bolts tightened down.
I didn't torque it all the way down to OEM specs, but it should be good.
Hopefully they wont bind at WOT
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
BIGxRED
Oct 19, 2015 10:47 PM
12vancover
Oct 16, 2015 12:04 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
