Door Speakers
Graphic/Web Designer
Door Speakers
Does anyone know if it is possible to remove the door speaker covers by removing just the arm rest and not the entire door panel? I've read some posts on removing the door panel, but I'm hoping I won't have to do that. In case you are wondering, I am changing the fabric on the speakers.
u have to remove the entire panel. and the speaker covers are heat molded to the panel, you will have to cut it out to change the fabric.
taking out the panel is easy. takes 1 minute.
the door panel is all 1 piece. it has to come off, but like el.cheapo said, it only takse a min or so to do!
yeah, its not the easiest mod, but it is time consuming. like el_chip said, you will have to do a few shave and drills
search for my thread on the speaker fabric.
Yes it is easy just like everyone said. You might have a little problem with the drivers front cause of the master switch harness is a little short and you can't pull out the panel that far. I think everyone will agree.
Sig Rho's Finest
even if you could just pull off the arm rest, you still would need to take the whole thing off if you want to change the fabric. like every1 said tho, its real simple. taking the door panels off is like a .5 out of 10 on the easy/hard meter.
man, the whole site is a little messy, I cant find my thread where I changed the speaker's fabric, if you can find it, you will be da man, lol... thanx
peacccccccccccceeeeeee
https://acurazine.com/forums/showthread.php?t=102858
thanx Kris, i was too lazy to search, lol.
and of course the pics are no longer hosted by acura-hypertek..
here are some pix from the other thread. Yes, I know its blue, I like it and it matches my all of blue neons and door sills.
soupi
14
11-15-2015 11:15 AM
polish_pat
09-25-2015 12:24 PM
