Door clip
Old Nov 10, 2008 | 12:22 PM
dammitjim's Avatar
Door clip
Does anyone know the part number for the door clip on the driver door for a 2003 TL-S?
There is a pin that holds the door and there is a clip that holds the pin. I'm looking for that clip. It looks like a "C"
Old Nov 10, 2008 | 02:43 PM
fsttyms1's Avatar
Holds what part of the door and to where? What clip are you referring to The hinge?
Old Nov 10, 2008 | 07:17 PM
dammitjim's Avatar
Yeah... I'll take some pictures tomorrow. The door is held by two hinges. The upper one has a pin and the pin is held in place by some kind of "c" ring. I need to learn what to call these things!!!
Old Nov 11, 2008 | 05:07 PM
TLer trash's Avatar
What you're describing is an e clip. It's not available separately from acura/honda. Take one off another door and take it to a hardware store to match up. If not a hardware store, an auto supply.
Old Nov 11, 2008 | 09:12 PM
totaledTL's Avatar
If it's #35 [94540-06014 E-RING (6MM)] here --> http://www.acuraoemparts.com/delray/...All&vinsrch=no it should be available separately.
Sorry don't know how to insert the image. Hope that helps.
Old Nov 12, 2008 | 11:37 AM
TLer trash's Avatar
My bad. I looked at that same diagram and missed it. Then my local dealer told me you had to buy the hinge.
Old Nov 13, 2008 | 11:56 AM
dammitjim's Avatar
Thanks for the info, guys... yes, I found it to be an E-ring (6mm) Part. 94540-06014. The dealer wants freaking $3.50 and special order and acuraoemparts.com has a minimum of 4 to order.
Do you think I can find this at a hardware store?
Thanks!
Old Nov 13, 2008 | 12:12 PM
TLer trash's Avatar
Yeah, hardware store or auto supply.
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
kixo
Sep 25, 2015 03:07 PM
