Do you have problems with remote radio switch? Heres the fix
My remote radio switch (the one on the left hand side of the steering wheel) has a mind of its own. Don't get me wrong, sometimes it works great. But most of the time it does what it wants, which may or may not coincide with what I asked it to do. I set out to repair this little problem of ours, and it's quite easy. I put together a PDF to help you along. Heres the fix. It should take less than an hour, costs less than 17 bucks and may or may not require the use of an impact wrench. These instructions may also help if you would like to replace your stock steering wheel. If you have any questions, don't hesitate to ask.
Thanks for the compliments guys. In fact, I do have another: https://acurazine.com/forums/audio-video-electronics-navigation-22/completed-non-navi-navi-conversion-296257/
Old news. First bulletin was 99-011 in 3-22-99.
New bulletin is 03-015 which is..
99-03 TL's...ALL
01-03 CL's...ALL
01-02 MDX...ALL
and 03 MDX vin 2HNYD18......3H500001 THRU 3H543590.
Any other info I'll be happy to provide.
All info will be Correct, guaranteed correct as per Acura.
99-03 TL's...ALL
01-03 CL's...ALL
01-02 MDX...ALL
Dealer should take care of this under warranty, supposedly a TSB is out.
Originally Posted by bkzjimmy
i wish there was a way to make the stearing wheel buttons work for an aftermarket hu
Originally Posted by Bxscig
I got it working with an aftermarket, there are solutions depending on your headunit.
I used the PAC SWI-X I believe that was the model # and it works "okay" It has a delayed response. But it does work. And it appears if I can figure out the resistances I can program it with anything it like and make more buttons elsewhere.
yeah, i had that problem, so i just took the damn stock HU out, and put my aftermarket, i have two remotes, one card remote, and one wireless punchable wheel from Sony which is attached to my steering wheel, so its all g00d..
but very nice DIY, I wonder how many ppl will deploy their airbags? (good luck)
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
